Hi, we have an hp e2200 that wont turn on at all....no beeps, no flashes, nothing. Nothing is wrong with the outlet or nothing because the moniter light will still come on but that it. Thank you for whatever info you can provide
Usually when a computer fails to start, and all it does is making repetitive beeps, it means that something is wrong with the RAM memory. Try to take off the RAM modules, clean the contacts, and put it back again firmly.
well if it wont display anything that means the chipset has been damaged somehow my hp pavilion did the same thing and i had to buy a new graphics card try opening up the computer and have a look if you see heat sinks in a square without a fan that will be the chipset smell it if it smells like burnt plastic it needs replacing
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor. 2. Connect the monitor into different power outlet. 3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Hi... I had the same problem... The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off. Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
