Question about Casio G-Shock GW300CA-1V Wrist Watch
Casio G Shock (Model G2300)
I'm trying to replace the bands on my watch. I've already taken the small screws out but the band seems to remain attached. Any help would be appreciated.
You have to remove the pins located under the band
Posted on Mar 20, 2008
Replacement band
You may try looking on ebay for the wristband.
Thank you,
Marcelo
Oct 23, 2013 | Casio G-Shock GW500A-1V Wrist Watch
Replacement bands for G304RL g-shock
Most stores that sell the watch also sell the bands. Or plug the model number into your search engine and buy one online. Spend time making sure it is the correct band as there are many different models and they are not interchangable.
Oct 08, 2012 | Casio G304RL 1A1V G Shock Street Rider...
Casio gw-500, trying to change the bands, screws keep turning
For G Shock GW500Uthe screws holding the ******** are actually just one pin per strap the screw end is for decoration. To remove just get small headed flat screwdriver and push pin through it is fidely but can be done it took me 10 mins first time. Casio sell straps direct for about 10 pound cheaper than putting into casio dealer .
Jun 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I have an new band for the G-shock 500A but can't figure how to get the screws out of the old band to replace it. The screws turn both ways and don't seem to move. Is there some trick or special tool I...
Yes, You need two screwdrivers. One for each side. One screw on one side is long and goes all the way through the watchband and threads into the screw oon the other side which is smaller. Once you have backed the longer screw all the way out, you should be able to give the watch band a few light taps and the long screw should fall out. The screw on the aother side may require a bit more tapping or coaxing with the screwdriver to remove it. Once both screws are out, you can remove the watchband.
Sep 22, 2009 | Casio G-Shock GW500A-1V Wrist Watch
I need to change my watch band
Where the band meets the watch - push the band a bit to expose the pins that hold it on.. The pins are spring loaded and will compress with the push from a tiny flat screw driver..
You can get replacement bands at most retal stores..
OR - take the watch to WalMart jewlrey dept and find a band that fits and they will help you chang it..
Good luck ;o)
Sep 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Change casio g shock resin watch band
It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
make sure you keep all original parts in case of toruble
Post a photo if you can after the change will be nice to see the change
Tom
Nov 10, 2008 | Casio G-Shock GW500A-1V Wrist Watch
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
How to change a watch band for shark freestyle model 788
Jim, you still need to remove the pins that the band is being held on with. You can use a small jewelers screwdriver to push them in.
However, I am having a tough time getting my new band on!
May 13, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
555 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
