Question about HTC TyTN Smartphone
Touch screen not working...
Have a problem with the touch-screen, it is not responding to anything stylus/finger/other... All other buttons and keyboard are working normally, just the touchscreen. Is there any way to fix it without resulting to hard reset, soft reset does not work... Any help would be great! Thanks!
  • 1 more comment
  • vincenttiong Apr 22, 2008
    i having same problem as JayKay81's has. kindly advise.
  • Sliverleef Jun 18, 2008
    tocuh screen not working but all ther key and phone function working normaly
  • Anonymous Apr 15, 2009
    I have the same problem my phone is a htc p4351 only see the windows mobil logo but the other botton working down the this logo
Hi guys,
i post this solution for those wo will be in the same situation in th next future. I had the same problem with my HTC TyTN (Herm 200). The touch-screen was simply not working. I read many 'solutions' on the net but none worked. I did not try the hard-reset because i was convinced this is not a software problem, and resetting the WM5 will not help. So i brushed the corners, looked for small particles which were pressing on the cover of the touch screen. but it did not work. finally i found one post (i don't remember where exactly) where a guy used a credit card and pushed it all around the touch-screen under the metal case (a bit harder). i tried it and it worked. i pressed harder especially in the lower part, above the buttons. and simply it worked ! no problem since then.
Posted on Jan 25, 2009
Solution 2 Helped! its working as before.
Thanks for posting
Posted on Mar 27, 2010
Thanks a lot
Posted on Apr 01, 2009
  • thewise Apr 01, 2009
    thank you very much
  • 113 Answers
Sorry to say probably not,
you can get replacement screens at WWW.HTCLCD.COM
Posted on Jun 18, 2008
Hello, My touch screen not function, but all switch work normal.When need touch screen to change something hi not work. the display work good .
Have you tried touching the screen with a pen, or stylus. Or even your finger nail? My KORG does not work well with fingertips, needs something harder.
Apr 01, 2014 | Korg Pa800 Synthesizer
Screen touch
Refer to the trouble shooting at Nintendo. Your screen may not be working due to the game your playing if any. If that's not the case you may need to recalibrate your touch screen.
http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_screen.jsp#respond
Aug 15, 2013 | Nintendo Dsi Pink Console
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
My Samsung star GT-S5233W's touch screen is not responding. I tried restarting the phone and removing the battery, but there's no response when I touch the screen with a finger or with a stylus. The outer...
The usual solution for such a problem is to have your phone's digitizer or touch screen replaced. That is the only solution for your phone's touch screen to work again. Have this done by a cell phone specialist, preferably one who's good with samsung phones.
Apr 09, 2011 | Samsung Star GT-S5233 Cell Phone
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen does not respond to the stylus what can i do?
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
I have Sony DSC-T900 camera which has recently problem with touch screen sensor in the right corner below. Any function button displayed at the tight side in the bottom of screen does not work or...
For the touch screen to work properly, the screen has to be absolutely clean. From the description, it is evident that the issue is confined to one particular corner of the screen, and any button appearing on that part is not responding to touch. This means that the screen is not clean at that portion. Clean the screen using a good quality micro fiber cloth. Make sure that the screen is absolutely clean and try using with a clean finger or stylus (Sony calls it Paint Pen or Touch Pen).
Aug 26, 2010 | Sony Cameras
My GPS just stopped responding to touch.
can you soft or hard re-boot your GPS?
(usually by holding down the down button + menu)
Jul 02, 2009 | GPS
Htc touch p3450 is not responding to stylus taps or finger taps
you needto replace the ants which live behind the touch screen
get some fresh once from your garden (or park) if you don't have a garden
Open phone( oh not allowed or warrenty void)
WHAT warrenty?
anywat open phone and you will see a few dead ants behind the screen.
Replace ants with fresh live ones
Close phone (quickly or ants excape)
power on phone
Never do hard reset on phone
It will electrocute some ants
Jan 07, 2009 | HTC Touch P3450 Smartphone
HTC Touch - Screen & touch flo problem
i did all things described to get the screen workin,pressed the red n green buttons simultaneously n with the friggin stylus i pressed the reset button underneath, pulled the battery out a coupla million timesn put it in, but it jus doesnt unlock, the touchscreen aint workin, i can call, mssag or do anything except recieve calls, Arpan
Nov 12, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC TyTN Smartphone Logo
803 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
