Question about Whirlpool RF315 Dual Fuel (Electric and Gas) Kitchen Range
Stove handle/door handle/oven door == I tried to pull the stove by the oven door to clean behind the stove but when I did that I pulled the oven door (the whole door) and it un latched from the hinges on the sides of the bottom of the door. I tried to pull the hinges on the door out to connect it back but they snap back wont connect. How can I conect it back?
  • 770 Answers
Need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Posted on Feb 26, 2008
  • Gary Davd
    Gary Davd Feb 28, 2008
    did you get it to work??
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do you open a new maytag self clean oven that a person locked the handle & now the door won't open.
wait fer it ta cool down and automatically release or go behind the stove and remove the rod that attachs from the motor to the oven door
Nov 03, 2009 | Kitchen Ranges
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
How do you self clean the oven?
look for the oven door locking lever ,on front,just below stove top & above top edge of oven door.pull lever out to lock door;dial up 'self clean'
Sep 25, 2009 | Ovens
Lock for self cleaning cycle in the on position
unplug the stove, then force the mechanism back with a screwdriver
Jul 22, 2009 | Ovens
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
My oven door came off and I can't get it back on
I have spilt milk flowing down the side fo oven/counter top and needed to pull out the stove to quickly get it wiped up..I pulled the stove out by the oven door handle. The hinge sprang on the right side and the oven door is now off on one side how to get it back on?? My husband lifted the door up and the whole door is now off.
It is very difficult to replace, what are we doing wrong???!!! Please help. I belive it is a whirlpool electronic model. thankyou.
Jan 08, 2009 | Jenn-Air JER8850 Electric Kitchen Range
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Aug 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven
It may have sliders inside the oven door .Open the door and look at each side for metal slide plates that when pulled upward they seal off the glass for self cleaning. If you dont have those ,I just wasted alot of typing.
Jun 07, 2008 | Kenmore Kitchen Ranges
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
Whirlpool RF315 Dual Fuel (Electric and Gas) Kitchen Range Logo
295 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
