Sony kp41s3u - blue screen
Switched it on and got an all blue screen one day (red and green are there but flash)
popped the back cover off and you can see the red and the green tubes flashing really fast, but the blue just sits there bright with no flashing.
Any ideas?
  • 2 more comments
  • FunkedUp Feb 26, 2008
    I dont have any distortion on picture, its just blue.
    I cant see any menus even if i did get them to come up. The menu on sonys are all green and the green tube is flashing really fast.
    I've tried unplugging things from the blue tube and then the blue doesnt start up at all but it does stop the others flashing. They are still dim though.
    I fixed it.
    turns out it was a bad connection on the box with the adjustable focus for each colour.
    No soldering or parts required!!!!!!
  • FunkedUp Mar 20, 2008
    ok the problem came back. Its not a loose connection on focus block but i can still cure it temporarily by swapping 2 colours on the back of the focus block.
    Any ideas whats causing this???
    President:
  • 4,402 Answers
Convergence amp ic bad or loose connection on ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Posted on Feb 26, 2008
  • Cary Farah
    Cary Farah Feb 26, 2008
    that would be the focus block. good job
    please post this as fixya!
I have the sony bravia KDF E50 A12U The tv went pop and wont work. On switching on the tv, the light stays green, then goes over to 3 red light flash then green. What is this and is it easily fixed?
  • This model had a problem with the lamp door warping from the heat.
Remove the door and hold it edgewise to see if warped..
There is a peg on the back of the door that engages a lever when the door is closed---if door warped set will not come on.
A simple way to confirm or deny this is to use something not metal to with the door removed ENGAGE and hold the lever forward.
DO NOT IF THE THIS SET COMES ON LOOK AT THE LIGHT OR OPERATE IT FOR PROLONGED PERIODS OF TIME.
Do not put the outer shield cover back on without the door as heat can get it also.
If set comes on with door lever engaged you need to replace the door--widely available on the internet and or from Sony---not a bad idea to buy a spare one.
let me know what happens.
Mar 15, 2012 | Sony KDF-E50A12U 50" LCD HDTV
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
SONY BRAVIA 50IN KDF E50A12U
i have the same problem on mine, my tv is only just 12 months old, in the last 4 weeks it had 2 new blocks put in as the tv was blue, it costing £700 each (under guarante for 3 years thank god) then lastnight the tv made a big bang then switched it self off and the sand by botton is now flashing red then green, i have to leave it 30 mins before i switch it on again then only last 10 mins before it does the same thing again, got sony coming out again to day to fix it, had it with this tv now hate it !!!!!
Sep 01, 2008 | Sony BRAVIA KDL-40V3000 Television
Screen slowly turns blue...
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jul 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Screen all blue
Try looking into the blue CRT lens while its on and see if the coolant has congealed. You will be able to tell if it has bacteria growing as this can cause the blue to be unresposive and make your screen have a blue haze. The coolant will need changing if this is congealed with bacteria. This is a common problem in all projection tvs blue and green are more prone to this sympton red is not.
Mar 30, 2008 | Televison & Video
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
KP41S3U LED FLASHES 12 TIMES
I dont think Sony has a "12" blink code, the highest (being in a newer set) is a "10", might try rechecking that, as for the code 2 that is an OCP, usually a shorted horizontal output transistor/Convergence IC's/High Voltage distribution block. My bet is the Block as HV tends to break down parts like that over time You must be careful when removing the anode leads as you can break the tip off or burn something up if not done right.
May 27, 2007 | Sony KP-41T65 41" Rear Projection...
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Sep 04, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Sony projection tv model # kp41s3u
hi the convergence ic's are ususally the problem. part no is stk4278l and they are located in front of the set behind the speaker grill. there are also teo fuses on this board that should be checked good luck
Mar 20, 2006 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
