Question about Philips 150B3T 15" Flat Panel LCD Monitor
Phillips monitor 150b3 no dispaly just power on
No display philips150b3
  • ernestonth Jul 24, 2008
    my monitor just to work fine but next day just a dark picture show cant control cos is yoo dark any hint ??? thanks
monitor on position and display show "AGING..."
plz solution
urjant
thanx
Posted on Mar 28, 2008
    Problem Solver:
  • 4 Answers
U guys suc at giving sulations to peoples problems
Posted on Mar 29, 2008
Va703m
This is a common indication that the power supply board has bad filter capacitors. When the capacitors go out the power board can not start up correctly so you get either a white screen, a flashing power light and no display, a flickering display or no power at all. The repair is easy, it just requires replacing the bad capacitors on the power supply board. About 10 minutes and a little soldering and your monitor should be as good as new. Here is a link to a repair kit with the correct parts to do the repair.
http://www.ccl-la.com/catalog/product_info.php?products_id=145
Apr 26, 2013 | ViewSonic VA703mb Monitor
Displays is blenk
if the display is totally black the cause is either dead back light or the power inverter get bad. if has a white screen but no picture it was a lcd controller board problem.
Oct 23, 2012 | Computers & Internet
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
845GLVA no display
remove all your pci card and troubleshut your ram, build in display or dispaly card, power sullpy, monitor and motherboard,
this problems occur becouse one of your hardware not working or more then one.
Jul 11, 2010 | Intel Motherboard
Was pink at bottom now a black screen. powers on for a second or two then black screen. green power light is on.
Check whether the connector has been properly connected to the computer. Also try to boot the system with safe mode option and you are geeting display, then install the appropriate display drivers will solve your problem.
Also check the DPI setting configured in dispaly properties.
Dec 15, 2009 | Envision H22W 22" Monitor
Hi - Received a LG monitor, W53 Series as a gift.
in your laptop there is button press f5 or f6 to get dipaly on lg monitor or you can right click and go to display properties and set the dispaly.
Sep 08, 2009 | Computers & Internet
No display
First open cpu cover then refix RAM memory.
Then power up then press F8 key then enter in enable vga mode go to control panel ->dispaly ->settings change screen resolution to 1024*768 .
If you still not get display check monitor to cpu vga port connection reconnect into it.
Aslo pull out cmos cell for 15 minutes so all bios settings are defaults then check .
you can find cmos cell on motherbord chip set in cpu.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 24, 2009 | Acer 22" X223w LCD Monitor
Moniter is not displayed energy star not came on
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
Aug 02, 2008 | Gateway FPD1975W 19" LCD Monitor
Monitor dispaly problem
I think this problem appear video o/p section.Dry solder Pl. solder video output section
Jun 01, 2008 | LG Computers & Internet
Philips 150B3T 15" Flat Panel LCD Monitor Logo
376 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
