Question about Garmin StreetPilot C320 GPS Receiver
Touchscreen offset Hi, can anyone help with a touchscreen problem on my Streetpilot C320? Basically the touchscreen bit has effectively moved so that you have to press a 'button' about 15mm below where it displays on the screen. Obviously not good for selecting the buttins on the bottom row of the screen! It also means I can't do a factory reset as that involves pressing the bottom right hand corner of the screen when powering up. The bottom right hand corner of my screen is somewhere about 15mm below the unit... Does anyone know how to reset this? Thanks, Deano
  • Deano58 Feb 28, 2008
    Hi Mabulok, thanks for the info. It worked a treat in the end. I had to repeat the process 3 times, as it kept drifting at first, but since recharging the C320 and using it this morning everything works fine again. Your help was much appreciated. If only Garmin could have been anywhere near as supportive...
  • 25 Answers
Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
Posted on Feb 27, 2008
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
Oct 16, 2013 | Garmin StreetPilot C330 GPS Receiver
Cannot recalibrate my Nuvi 50
Please see this link on how to recalibrate your touchscreen. The procedure should be the same as a Nuvi 14xx.
http://www.sharc.net/discus/messages/6/77.html?1315261162
Mar 30, 2013 | Garmin StreetPilot C320 GPS Receiver
How do you troubleshoot if the garmin gps suddenly just don't want to turn on even if it is plugged on the charger?
Try a "Master Reset" on your StreetPilot c550:
Power the StreetPilot off (ensure that it is not connected to external power)
Touch-and-hold your finger in the lower right corner of the Touchscreen...
Power the StreetPilot on...
Continue to hold your finger there until "Erase all user date?" appears...
Remover finger from the Touchscreen...
Touch "Yes"
If this doesn't work check to see if your item is still under warranty. If not I can provide you with a place that fixes gps' relatively inexpensively. Hope this helps.
Mar 09, 2011 | Garmin StreetPilot c550 GPS Receiver
LG Incite touchscreen not responding
try to reset the phone by picking the reset hole on the side of the phone (i use a staple) the touchscreen should be a bit better to press the unlock button. hope this helps!
Nov 16, 2009 | LG Incite Cell Phone
The c550 unit i just purchased stopped acquiring the sat. Help!
Touch "Yes"
Nov 28, 2008 | Garmin GPS
How do i reset the c550
To perform a master reset on the StreetPilot c5xx series:
1. Power the StreetPilot off (ensure that it is not connected to external power)
2. Touch-and-hold your finger in the lower right corner of the Touchscreen
3. Power the StreetPilot on
4. Continue to hold your finger there until "Erase all user date?" appears
5. Remover finger from the Touchscreen
6. Touch "Yes"
Please rate the solution....
Thank you
Nov 14, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin c320 installation
You should contact the manufacture rep, or the manufacture directly and ask that question. From my own experience they will tell you that you have to buy a new copy. The software is a bit on the expensive side.
Jerry G.
May 31, 2008 | Garmin StreetPilot C330 GPS Receiver
StreetPilot C330
Did you try the reset button after it come on.
Try that first.
Dec 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Touchscreen not working
You could try resetting the device by:
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the faceplate.
3. Press the reset button
4. Turn the unit back on
If that still doesn't take care of it then you can try to contact Garmin to see if they have a replacement touch screen or if they can repair it, but the product is discontinued.
Nov 23, 2007 | Garmin StreetPilot C320 (010-00401-00) GPS...
Garmin StreetPilot C320 GPS Receiver Logo
171 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
