Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I have a 722k Dish dvr, and my 5.3 remote stopped working today.This is after working fine for 6 months. I had an brand new 5.3 and that one also did not work today. Dish support had me try the new 20.0 ir remote that came with the 722. It would also not work, so dish is sending a 21.0 remote tomorrow.The tech said a 21.0 remote has a switch to set to ir. Is the tech correct ?
5 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: No Picture on our Mitsubishi WS-65813
I had this same problem last year, i found a document on some forum that walked me through every step and the TV was fixed for less than $10. Send me an email to bclrk1@yahoo.com and i will reply back with the PDF.
Ben
Posted on Dec 17, 2008
SOURCE: Xbox 360 or Dish ViP 622
when i hook either my dish hd receiver up to the 1080i component video inputs, everything works fine if i set either device to 480p, but i get nothing i set them to 1080i.
Posted on Jan 27, 2009
Neiday
SOURCE: Timer light won't stop flashing, no powers since setting timer
DM BOARD replace entire board (New $707.25 Used: $325-561.25
Replacing few capacitor will be temporary fix, at best.
Advise: Please get 3-4 yeras of warranty on such a big-ticket item
Posted on Feb 11, 2009
  • 10865 Answers
SOURCE: I need a remote code
Sadly your problem is common among Dish customers, including me. There is no code for the combination you are seeking. The only way to get yourself down to the one remote is to get a remote called a logitech. here is an article about that brand. http://reviews.cnet.com/best-universal-remotes/
Posted on Feb 22, 2010
I need a remote code for my dish network VIP722k DVR with my sony RMVZ320 remote
Check with DiSH for a possibly unpublished code. You may find that only the DiSH remote will work.
Jan 01, 2014 | DISH Network IR Remote Control
Tip
DISH VIP612 Program AUX Remote Code
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
Duo DVD 625 to HDMI
Hi my name is Mike Houston a Social Media Representative at DISH. With our Duo SD 625 DVR, it cannot receive HD signal, there will need to be an upgrade to our HD duo DVR systems. If you have any further questions about our DISH equipment please e-mail me at; michael.houston@dish.com
May 29, 2012 | DISH Network DVR-625 DTV Receiver /...
How to program a dish 3.2 IR remote to control a dish vip 722k dvr
Open the door on the receiver, and hit the menu button twice. With the remote in hand, hit sat, then record. Then use the remote to exit the menu. Voila!
Apr 07, 2012 | DISH Network IR Remote Control
Have DVR 722K and want to change TV2 to remote IR however system will not allow. How do I get system to take this change?
Hello, my name is Tommy Faust with DISH Network. I would be happy to clarify this for you.
At this moment our second remotes only work via UHF. We're unable to change them to IR as that requires a direct line to the receiver which is usually in a different room/part of the house.
Hope this information helped you! Feel free to post here if you have any other questions.
Nov 28, 2010 | DISH Network IR Remote Control
Dish hd dvr remote won't work. brand new. it
It sounds like you have interference, try removing the uhf ant from the back of rec and promgram it straight from there. you can also hookup "bunny ears or a pigtail coax to the uhf ant port to increse uhf signal. also make sure the uhf ant is standing straight up.
Nov 13, 2009 | DISH Network 721 DVR Remote Control
Emerson tv wont work with dish network remote
the code for an emerson320em1f is to hold the tv button at the top of your dish remote until all buttons flash red, then enter in 632#, then hit your satellite button, and everything should work
Sep 28, 2009 | DISH Network IR Remote Control
Same problems. Fan is whirling. Light flashes. No Video Signal.
The 622's are good receivers it is just that on occasion we get a shipment that has been mishandled. This causes the issues however a 722k is a good choice. Thanks for using Fixya.
Jun 26, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Brand new dishnetwork 622 DVR UHF remote does not work
Contact Dish Network tech support. If they can not fix it for you over the phone then they will send you a free replacement. Hope this helps.
Apr 01, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
