Question about Hitachi 53UWX10B 53" Rear Projection Television
No power all of a sudden
I have a Hitachi Ultravision TV that lost all power tonight not long after turning it on. It made a loud noise through the speakers before it went black. It then starting clicking, and the red power light starts blinking in time to the clicking coming from the back of the set. I have had the convergence problems with this set and fixed it (with the help of a friend who solders electronics), and it has worked flawlessly for about 2 years since doing it. I did smell an electrical smell after it happened, so I'm guessing something burned up. Any help on this? Great timing, but the way. The washer just started leaking, too.
Steve
My Tv power light in front blinks on and off with a chirping sound that corresponds to the blinking. There is no picture. I have fixed a convergence problem in the past. I'm not a pro so please make the answer as simple as possible.
  • Anonymous Jul 06, 2008
    no raster or sound two green led blinking in time with chirping sound from high voltage board. I haven't done any soldering for a long time. not sure where to begin. I am assuming the chips you are talking about are high watage transistors on the neck of the tubes? Any help or direction would be helpful thx.
    President:
  • 4,402 Answers
Im thinking you blew the chips again, i would use sanyo chips from mcm not cheap ones
This is a list of most of the commonly used STK devices and some that Sanyo made that are rarely, if ever, used. I will add links to the data sheets that I have, but some of them are not available. Some of the chips are versions made for a particular TV manufacturer, and Sanyo does not provide data on those, typically. It is generally best to use the same chip that is found in the set. However, there have been newer versions of some of these produced that are identical in performance and superior in certain applications. I will note my recommendations and the logic behind them, but I in no way, nor does HTS, take any responsibility for the accuracy of the information with regard to substitution of parts. Any substitution is your responsibility. I can only relate what I have found to work with parts that I know to be original Sanyo parts.
STK4273 replace with STK4274 if heat sink allows
STK4274
STK4275
STK4278
STK391-110
STK391-120
STK391-220
STK392-010 replace with STK392-040
STK392-020 replace with STK392-040
***The -040 has wider bandwidth and has higher current rating than the -010 and -020. I use in ALL cases to replace the older versions.
STK392-040
STK392-560
STK392-570
STK392-110 replace with STK394-160
STK392-120 Hitachi replaces these with STK394-160, for other sets it may not be a good sub. They have been fine in the Philips sets so far.
STK392-150 replace with STK394-160
***The 394 series replaced the 392 series and is cooler running. The subs listed here are the ones that I know to work in most sets.
STK392-180
STK392-210
STK392-220
STK393-110
STK394-160 (This is my choice to replace the STK392-110, -120, & -150 in most sets and are available in the Hitachi kits in the next post)
STK394-210
STK394-250
STK392-260
STK394-510
Suffixes
-L means bent pins for horizontal mounting
-E means lead free
-HIC in Mitsubishi parts simply means that it is an IC on a heat sink and is irrelevant to buying parts.
Posted on Feb 26, 2008
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Did my tv just blow up?
Yes, I think you have lost the bulb and maybe the color wheel is on the way out too. But try a bulb first. If the old one has a broken "glass tube" in the center--be assured it is bad.
Oct 10, 2009 | Samsung Televison & Video
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
Aug 04, 2009 | Hitachi UltraVision 42HDS52 42 in....
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Jan 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Booming noise
10 years is about life for these, booming noise like a gun shoot?
i would suspect a cap blew up can you open the back and see any burn marks or paper ?
Nov 26, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Big screen t.v. UltraVision
take it to a tech for repairs the power supply iis defected 0r related circuit.good luck.
May 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
778 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
