Question about HP Pavilion dv6000z Notebook
My computer no longer seems to recognize wireless
Can't find a network, and won't connect
  • ahall31 Feb 26, 2008
    Problem is it worked fine for a year, all of a sudden it stops? Ahhhhhhhh! The other computers in the house work fine!
  • 813 Answers
Can u intalled network driver proper
then after chak ip address
then afre chak the netwok cable is it ok or barked
if u have wifi
chak the mac & tcp /ip address of ur wifi router
Posted on Feb 26, 2008
I just used recovery disk to restore back to factory setting for acer aspire 7741Z. Now it won't recognize my wireless router
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 28, 2012 | Acer Aspire 7741z
Hello, I am trying to install my d-link 125 usb adapter. I had to download the windows 7 driver from the d-link website, and now I am trying to install it to my computer. When I try to run the driver...
Use the following steps to let Windows do the installation for you.
Step 1: Use an Ethernet cable and plug your computer directly to your Internet gateway. Make sure Internet is accessible.
Step 2: Place your new adapter in the proper slot or port.
Step 3: With your computer running, a bubble message will appear stating that this device was not installed successfully. Left click on the message.
But if the message no longer appears, skip to Device Manager Installation.
Step 4: On driver installation failure, you can change the setting to use Windows Update by clicking Change setting...
Step 5: Chose to allow Windows to update your driver when it is not found on you computer.
Step 6: Once the driver installs successfully, close the window.
Step 7: Click/Right Click on the Network Icon located on the system tray to View the Available Wireless Networks. Find your personal Network and double click to connect. It should request for a wireless key, which by now should have been set up.
Oct 26, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
Although my Asus once recognized my home wireless router, when Comcast sent us a new wireless router to use and a new home network was set up, my computer no longer was able to connect. I can access...
To connect to your wireless router, it needs the router's wireless settings configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2011 | ASUS Wireless (90-c1i010-00xay)
My Asus M50Vm notebook is no longer recognizing my wireless network. I have gone to the website and updated my drivers, but I still cannot connect wirelessly. I also checked to make sure the wireless...
I'm assuming by 'no longer recognizing my wireless network' that at one point in time your notebook was connecting without problem, but now for whatever reason it's not connecting because your Wireless Network (SSID) is not showing up when your notebook scans for networks.
If you remember what your Network's SSID is called, I would try setting your wifi card to connect to it manually vs connecting to 'any' SSID in the area. Wifi networks won't show up when you scan for them if they're set to not broadcast their SSID's.
That is the most mundane assumption I can make as to what's wrong. There are a bunch of other problems that could cause this, but I'd try this solution first.
Apr 22, 2010 | ASUS Wireless (90-c1i010-00xay)
Acer one and netgear WNDR3300 router
Make certain tha you have your firewall setting allowing the wireless card to connect. When you type your password in make certain that your caps lock is not turn on. Finally if your computer can only run wireless B, you have to tell your to broad wireless B and G, or do a protection mode, where older wireless device will connect.
Oct 10, 2009 | Computers & Internet
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Can't connect to netwoork
Just configure the wireless settings your laptop. Go to Network Connections > Right-click on Wireless Network > Properties. Go to Wireless Network tab and look for Preferred Networks. Just remove all of them and click OK.
Now, On the Network Connections, right-click on Wireless Network Connection > View Available Wireless Networks. Connect to your own wireless network and enter your wireless network key if it tells you to type it. That should fix your wireless connection. Now if your wireless network is not showing, you need to change the wireless channel of your router by accessing the router's setup page using your wired computer.
Apr 18, 2009 | NetGear WGR614 Wireless Router
Trying to connect to the internet wirelessly
is it detecting in the device manger if it detects in the device manager it show in the network connections . i think there is a switch for wireless enable or disable on the laptop
Mar 24, 2008 | Fujitsu LifeBook S6231 Notebook
I am no longer able to connect my wireless router...why?
Hi canuck07,
Here's how to remove the ad-hoc setting (I'm assuming you're running Windows XP):
1) Right-click on the wireless icon on your system tray (right end of taskbar) and choose "Open Network Connections,"
OR go to Start Menu > Control Panel > Network and Internet Connections > Network Connections.
2) Right-click the wireless connection and choose Properties.
3) Select the Wireless Networks tab.
4) Under "preferred networks," select your network and click "Properties."
5) On the Association Tab, the bottom check-box corresponds to ad-hoc networks - uncheck it.
Hopefully this will make your adapter able to find your network. Please let me know if this doesn't work, or if I can be of any further assistance.
H2H
Dec 26, 2007 | Linksys (WMP54GS) 802.11g/b Wireless...
HP Pavilion dv6000z Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
