Question about GE WSXH208A Front Load Washer
Starts out draining
My washer seems to be shooting the water straight out into the sink at the start of the normal cycle, like it's getting ready to rinse before washing has even started.  It is also much louder than it used to be.  It seems to work ok on the permanent
press settings.  Any ideas on how to get the normal cycle back to normal?  Thanks!
What you are experiencing is what i have experienced for the past 6 months...do something now before it gets worse.....
I have discovered that there should be a warning with the NEW FRONT LOAD washers, and that is....ALWAYS EMPTY out pockets of clothes. WIth the typical top load machines...its seems that the "stuff" we left in pockets, ended up in the bottom of the disc of the washing machine, and actually became a game with me...how much money could i find after washing my husbands pants!...never able to go much further than that....but with the front load machines....whats left in the pockets, gets "eaten" by the machine , and the rubbery entrance in the front of the machine.....but items never to be seen, until you pay the a repair man to come out and tell you what you shouldn't do!
SO....sounds to me like, your drain hose is getting clogged, what you are experiencing is what i was experiencing for about 1 month before the machine just stopped working altogether! you can take off the front bottom cover (there are prob screws there) and then there should be a hose and sometimes a trap (where, if you are like us,...the repairman found about 5 dolloars worth of coins) that you can empty out...i guess depending on you type of machine....mine was a GE)
Posted on Mar 13, 2008
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Dishwasher won't drain or seems to drain to other diswasher.
possible blockage at sink pipe where the drain hose connects to. the drain hose is attached to the spout on the pipe. remove the clip holding the drain hose to the spout, remove drain hose gently, put drain hose into a bucket and then turn unit on to a cycle. it should start draining straight away.if it does drain into bucket u have a blockage in the spout. put a small screwdriver into spout to unblock . then put drain hose back onto spout with clip and run a cycle. before i forget when and if the water starts draining into the bucket turn off the unit so u can put the drain hose back on. if u need more help please reply. good luck.
Apr 27, 2010 | Fisher and Paykel 23 in. DD603H SS...
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops and will not drain, appears to be clogged.
There should be a large drain plug on the bottom front right hand side. Unscrew it and check for items stuck in there, normally a sock or hair clips etc be careful there will be water in there so be ready with a mop. If it's clear, no obstructions check the drain pipe isn't kinked or squashed, it's worth pulling the machine forward putting the end of the drain pipe in the sink and watching what happens while it goes through a washing cycle.
Apr 30, 2017 | Kenmore 24082 Top Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water pooling up in bottom of dishwasher
is there any way to run the cycle from the beginning and listen to hear if the machine is draining at all when the cycle starts do you hear the water spraying on the inside ? if not then you have several different possibilities....clogged drain line, pump impeller broken(sounds like running but no action), water just flowing back to washer the last one's an easy fix just loop the excess drain hose up like a reverse "p" trap on a kitchen sink drain this keeps the water from flowing back to the machine
Dec 15, 2008 | Whirlpool Dishwashers
GE WSXH208A Front Load Washer Logo
41 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
