Question about Spidem Trevi Automatic Espresso Machine
Coffe not hot enough
Is there any way to increase the temperature of the coffee without having to microwave the cups before dispensing the coffee?
  • Anonymous Mar 30, 2014
    Coffee is not hot I need to microwave to temperture
  • 2,039 Answers
Lot of time calcium in boiler = lest heat descale it with descaler not vinegar if our not sure how to descale let me know it would be my pleasure to help you
thanks for using fixya
pierre
Posted on Feb 26, 2008
Water not hot enough
Set the temperature to "extra hot" If still not hot enough, try zapping your coffee for a few moments in the microwave.. no coffee machine will boil the coffee as this would burn and cause an awful burned coffee taste
Apr 19, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
DeLonghi Magnifica 3200 how to increase coffee temperature?
Evening to you
Not hot enough, do you leave it to stand with the green lights on?
By my experience the machine is best left on so everything is hot when the water passes through.
To let some time pass before you make the next cup.
And lasly to make sure that machine is clean.
Good luck
kolbrun
Mar 05, 2012 | Faberware FSCM100 Coffee and Espresso...
How to increase temperature on model BCM120. The coffee is not hot enough after brewing. Is it possible to increase the temperature on the thermostat.
There is no temperature adjustment for the heating element under the carafe.
The Instruction Manual says:
If coffee is too cold, machine not preheated, cups not preheated, milk not heated enough (if making a cappuccino or latté)
Jun 12, 2011 | Breville Coffee Makers & Espresso Machines
Hello We have a prima donna machine and
Check your programmed temperature setting; perhaps your machine has been set at low or medium.
Following are the instruction for Setting the Temperature from the manual for the ESAM6700.
1. Press the P button to enter the menu;
2. Press the < or > until "Set Temperature" is displayed;
3. Press the OK icon;
4. Turn < or > until the required temperature (high, medium, low) is displayed;
5. Press the OK icon to confirm (or the ESC icon to cancel the operation);
6. Press the button to exit the menu.
For a hotter coffee, before delivery rinse the appliance through by pressing the Rinse icon and confirming with the OK icon. Hot water
flows out of the coffee spouts and heats the internal circuit of the machine so that the coffee delivered will be hotter.
For an even hotter coffee, heat the cups by rinsing them with the hot water.
Mar 22, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Aug 31, 2008 | Saeco Royal Professional Espresso Machine
Coffee not hot enough
My coffee machine doesn't get very hot either, I add hot milk to the coffee in order to raise the temperature a bit.
May 17, 2008 | Miele CVA4070 Coffee Maker
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Spidem Trevi Automatic Espresso Machine Logo
182 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
