Question about HP OfficeJet K80 All-In-One InkJet Printer
Scanner Failure Pls. advice regarding the scanner failure error message HP Officejet K80 printer. Thanks a lot.
  • 2 more comments
  • yo_paisan Apr 29, 2008
    I have the same problem. Just one day my copier, scanner, fax stopped working. I can still PRINT, but I can not scan, copy, or send a fax...
    I would really love to know if there's a fix. I'm guessing it probably needs to be taken into a repair shop but... if you know how to fix it I'd love to fix it myself. Thanks!
  • Anonymous May 25, 2008
    Same problem. The computer will print but states that the scanner is not available.
  • mdefenbaugh Jul 09, 2008
    hp k80 all in one will not fax or scan, says scanner failure...Help
  • tropicalspac Mar 12, 2009
    I have a similar "scanner failure" problem, the printer smells badley like something is burning. I have top keep it turned off. It will print thought, any ideas?
Thanks to "Guest" - the same solution worked for me - I unplugged the power from the back of the printer and it solved my problem. I could print but not copy - and even could not print from one of the two PCs hooked up to the printer. Thanks so much for the solution! I didn't think it would work and you totally saved me from buying a new printer!!
Posted on Jul 14, 2008
    Scholar:
  • 87 Answers
U will need another scanner assembly..note i said another and not new....HP does not make inkjet parts available. Your best option is to find a used one of which we have. Replacement will require minor disassembly of the printer, left and right side covers, undo a few plugs, remove two T-10 screws and the entire assembly lifts out.
Inkworks
Posted on May 22, 2008
Scanner won't scan
Posted on Apr 27, 2008
I had the same problem along with the problem of "remove and check color cartridge." Nothing worked until I completely disconnected the power to the K80, both from the wall and from the K80, and left it disconnected overnight. In the morning all worked great. The problem was gone.
John
Posted on May 23, 2008
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
HP k80Xi Scanner failure
for all-in-one printers very often we must install drivers for the scanner section and some times the universal drivers under your model works fine you sure try that.
Oct 04, 2012 | HP OfficeJet K80 All-In-One InkJet Printer
HP C6180 Scanner Failure error message
You need new scanner section but try first to clean this one.Disassembly the printer and pull out the scanner section.Open it cover and inside you'll see the mirrors.Clean the ash from mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Oct 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
K80 "scanner Failure"
same problem here...error message says scanner failure - power off then on, but also doesn't work , ges what , id did buy the same in 2the hand , also same prroblem this is sh...
Jan 11, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
HP OfficeJet K80 All-In-One InkJet Printer Logo
352 people viewed this question
Seeker5211
Seeker5211
