Question about Electrolux EW1000i Front Load Washer
Indesit washer/dryer wd10
Hi wonder if you can help?we have an indesit wd10.
put on any wash cycle the machine just carries on washing.
We have to turn it off and manually put it onto rinse and spin cycle which it will then go through correctly.
Any ideas? Regards Mik & Julie u.k
  • 185 Answers
Change the timer
Posted on Mar 27, 2008
I have an indeset WD10 washer/dryer. When I put the programme on, it just clicks round and keeps clicking round until I turn it off. Does anyone know how to fix this problem?
Regards
Sharon
Posted on Mar 11, 2009
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit wd10[uk],when placed into wash cycle 4 ,washes,then spins and after spin returns to wash 4 cycle,ad infinitum.
strip down programmer/timer motor,found contact fingers not making circuit with printed circuit card,adjusted fingers,rebuilt timer,tested,ok.$100 please mam!
Feb 27, 2008 | Indesit Dishwashers
Wd10 indesit washer banging
It could be the drum bearings. If you can move the drum up and down, the bearings is worn. It could also be the balanceweight that sits on the top of the outer tub that have gone loose. It's usually made of cement, or cast iron.
Jan 23, 2008 | Indesit W 123 Front Load Washer
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
INDESIT 167 Stuk on DENO
take the lid off the machine.remove or disconnect the wires off the main board giving them a small spray with a water dispersent or silicone based soloution.by the way turn the power off at the mains before carrying out this procedure.
Jun 29, 2007 | Indesit W 123 Front Load Washer
Electrolux EW1000i Front Load Washer Logo
346 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
