Question about JVC PD-42V475 42 in. HD-Ready Plasma Television
Wash out Color is going and white specs all over TV. When there is a white back ground, color completely washes out. TV does the same thing when I play dvd's.
  • 395 Answers
You will need to have the logic board replaced this is the part number LJ92-00975A. the SSB modual may need to be replaced also but start with the logic board.
Posted on Feb 26, 2008
  • 2,326 Answers
I would suggest to check your video settings like the brightness, contrast, colour and the Tint as well other picture settings. Try to keep them to about 50% on each adjustment.
If the settings appear normal and you still have the wash out, the video processor board assembly is defective.
In many occasions these defects are generated in the power supply as well.
For a board level troubleshooting you should take the TV to a repait tech or if the TV is under 1 year old; still under manufacturers warranty.
Let me know if I can assist you further.
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
Slow leak under unit cannot find problem. what specific should i look for?
It is most likely a hose connection from the pump to drain. What you could do is fill up the washer with cold water and color the water with food coloring let the washer rn thru a cycle. on its completion of the wash cycle and after it drains do not let it fill back up. Turn the water supply taps off and til the washer over on its front. With a tissue,(white), find the spot arond the connections where the color has dripped from. Repair that conection and with the washer back uprite run thru a complete cycle to test for leaks as well to purge the color out of the system. You either must do the later or run like h--l if the wife gets that color on her clothes. lol
Sep 28, 2010 | Kenmore 23822 Top Load Washer
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How do I colourwash my LG Plasma TV model LG 42PC55
In the menu selection you should have something in the options called ISM Method. Set this to "color was" to wash colors out, then use the white wash to get the ghost out. It is also recommended that you use your plasma at 50% contrast as the gas used to display color needs time be evenly worn down. I have a brand new 50" LG 1080p full HD 600Hrz that I bought last month, and I already have burn in because I didn't read the manual. Make sure you're using the orbital setting during the first 200 hours as well this will reduce the intensity of the burn.
Feb 20, 2010 | LG 42PC5D Television
My tv has color yet my vcr/dvd player has limited
The problem may lie in any one the following things.
1. Cable you are using
2. You set your video color system properly(NTSC/PAL/Scam) You fix it only auto color
Dec 30, 2009 | Televison & Video
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
The first thing you need to do is to take away the color completely, then you adjust the hue until you get the picture looking like a black & white tv, like the old shows that were broadcast in black & white.
Then you can gradually add the color. And thats it your done!
Jul 19, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Only black and white
The same thing happened to my HLP5063W. Researching the internet forums I concluded the problem was with the color wheel, which I replaced. As it turns out the old one was completely smashed. Go to for replacement instructions.
Jul 05, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Sony KV-27TW75 Black and White Picture
this is usually due to bad ground check cable line comming into tv and
Feb 04, 2008 | Televison & Video
JVC PD-42V475 42 in. HD-Ready Plasma Television Logo
244 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
