1996 Dodge Neon Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
97 dodge neon timing belt single overhead
Manual only shows for dual overhead. need specific instructions on what to do after the old belt has been removed
thanks
Anonymous
Level 3:
  • Master 617 Answers
  • Posted on Feb 16, 2010
Anonymous
Master
Level 3:
Answers
617
Questions
0
Helped
241484
Points
2043
96 OR 97? which engine and 8th digit number and email address to send diagram to
Where is the fuel filter located on a 1996 dodge neon single overhead cam at
on top of the fuel tank. this is a single line fuel system and that is where they put it. the tank will have to be lowered to change it.
How do I replace an alternator belt on a 97 dodge neon?
Rather than go into a long winded answer to your question, may I suggest you go out and buy a Haynes auto repair manual for your 1197 Neon at your local auto parts store. In it you will find detailed instructions on doing that and a whole lot more!
2helpful
2answers
Change sepertine belt on engine.
it is not that fun, you need to have 1/4 inch tools, 10mm socket 8mm socket, 12 mm socket,18mm socket. and wrenches to match. you need to support car on jack stands and remove pass tire. Go to your local auto parts store and get a manual first. as the valve timing is very critical in the installation process !!!!!!!!!!! if this timing is not done exactly you will cause severe engine damage to valves and pistons. read manual and read again then assemble it right the first time as there is no room for error. Belt is 30 -50 $$$ depending where you go.
What are the steps to change a water pump on a 2001 dodge neon?
disconnect cables from battery, drain radiator, Remove the Timing belt cover, timing belt, timing belt tensioner and if needed the timing belt rear cover, remove the bolts that hold the pump in place using a criss-cross pattern. Install the new pump making sure the o-ring seal is properly installed and replace all the other parts. If you need step by step instructions on how to do all these task I recommend the Haynes Repair Manual on your vehicle Manual 30036.
2helpful
2answers
How to repair timing belt
Click on the following direct Link. It has some of the Timing Belt Diagrams that you will need. Plus additional Instruction and Directional Diagrams you should use.
As far as "how", with this type forum - it would literally take several dozen pages of instructions - from start to finish. I would strongly suggest buying a Haynes or Chilton Manual available at most auto parts stores. They cost $20-$25. These include specifics including Torque Specifications of each and every Bolt or Nut.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1989/make/dodge/model/spirit/1989_dodge_spirit_timing_belt_diagram_marks.htm
2answers
How do you replace timing belt on 2002 ford escape 4 cylinder
need to know which four cylinder you have. single or dual overhead cam.
Need to replace a timing belt on a 97 double over head cam neon
Go to the autozone website at autozone.com and register your vehicle. It's free and you will have access to an online repair manual for your vehicle. The steps for replacing the timing belt on your vehicle is there. ( I checked). Hope this helped and best wishes.
2answers
Instructions on how to change timing belt on a 1997 dodge neon sohc
motor vehicle technician for this job,not a weekend mechanic job
Timtin belt broke
new valves fitted ??
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
