Question about Baby Gear
Cam cup torque settings
I need to know what the camcup torque settings must be as I have replaced the old lifters with new ones.
  • 50 Answers
On what car?
Posted on Feb 28, 2008
How hard is it to change lifters?
It is not difficult in most overhead cam engines. The lifters are easy to get to taking off the cover(s). The problem is that lifters are seldom the entire fix for the problem. Usually, the valves and valve seats need work, and sometimes the cam shafts, so the entire head has to be removed. When you remove the head ALWAYS USE NEW BOLTS and torque them to the manufacture's specifications IN THE CORRECT TORQUE ORDER. Use a new head gasket too and break the engine back in as you would a new car for the first 2K miles. There is a discrete pattern for tightening the head, use it! Find a good machine shop before you get started. Line the engine up to TDC first and make an index mark so you can see if it's moved on you to realign it easily to keep your timing in spec.
Mar 12, 2015 | Cars & Trucks
What is the torque specs for a 1999 mitsubishi eclipes 2.0l , the cam caps
Have you carried out any repair as yet? why do you need torque setting for cam caps
May 23, 2014 | 1999 Mitsubishi Eclipse
I am experiencing aweful lifter tick. As of now, I have replaced all of the lifters and the oil retention valves. I have tried different types of oil, and nothing is helping.
Did you change the cam and lifters or just the lifters? New lifters and an old cam may not spin properly. They are suppose to wear in together. Replacing one and not the other can make it worse than it was. Always replace them as a set. I'm not one for engine additives. You can try replacing a quart of Lucas Oil in place of one of the quarts of oil in your engine.
Mar 19, 2011 | 1997 Audi A6
How to replace lifters on a 360 V8 engine?
I find it hard to believe that it runs fine but, to replace either, you need to remove the intake manifold. Likely you will find both items in the lifter galley. Before dropping a lifter in there, make sure the cam lobe is still good....If the old lifter is severely worn on the cam end, likely it's not. After replacing the parts, but before replacing the valve cover and manifold, turn the engine by hand and make sure that the valve opens and rocker travel is the same as all others.
The r&r is covered in haynes and chilton manuals. One tip is to always use washers on any bolt that attaches the manifold to the heads to spread the torque load and yes, always torque any aluminum manifold to prevent warpage..
If either part has fallen into the oil pan (unlikely) it actually can stay there forever without harming anything.
Jul 22, 2010 | 1987 Jeep J-Series Pickup
Are the valves adjustable?
hi, on your vehicle the valves are not adjustable after about 1990 they started using hydraulic lifters, so if you have top end engine rattle then the chances are these lifters will need replacing or worse case the cam lobes could be worn if this is the case then your going to need to do a top end rebuild.
to replace the hydraulic lifters your going to need to remove the cams so as you can get to the lifters under neath the cup they sit under so its quite a big job.
the older type valves were a lot easier as you could adjust them with screwdriver and measuring guages but they started using the new ones as they made less noise and lasted longer, but the downside to this was that you need to do more work to replace the lifters.
let me know how you get on or if you need further assistance ok
Jun 13, 2010 | 1994 GMC Sonoma
Ticking noise comes and goes i took it to the dealer they said the camshaft and the#6 lifter is bad do i have to replace the engine
should be able to rebuild. sounds like you will need a new cam and lifter set. Cam and lifters could be replaced without completely rebuilding engine, but I wouldn't recomend it. All the metal from the cam and lifter goin down will have already gone through your oil system therefore engine really needs complete disassemble and cleaned.
Jan 16, 2010 | 2001 GMC Yukon XL
What would be the torque setting for the cylinder head of a mazda 323 familia with a b6 engine, twin cams. thanks.
Remember you have pre loaded cam gear's that have to be loaded, or it will make kinda of a lifter noise but not lifter's.
Torque
step #1 17-19 ft.lbs
step #2 additional 85-95 deg
Nov 19, 2009 | 1994 Mazda 323
Part requirments for Cam and lifters
Yes you will need the following:
Cam
Lifters
Assembly lube
Water pump gasket
Intake gasket
Timing cover gasket
Lifter removal tool
Puller for harmonic balancer
Cam installation tool/removal tool
I also would recommend replacing the timing chain and timing gears since you are going to have to take the timing chain off anyhow.
You will also need the associated tools to do the job, plenty off rachets, box wrenches and such.
If you are doing mechanical lifters you will also a feeler gauge to measure the valve clearance and make adjustments.
I cant think of anything else off the top of my head.
If you are doing a cam with more lift then I would recommend replacing your valve springs as well, it is easy and it will assure you do not incur valve float. You will have to take the rockers off when you install the new lifters because you have to remove the pushrods. I also recommend you replace the pushrods while you are at it, they are cheap. You will need a valve spring compressor and new valve springs and locks, they are pretty cheap.
Oct 29, 2009 | 1983 Ford F 250
Need advice on how to set rocker clearance for 2.5 turbo deisel
You have hydraulic lifters which are not adjustable. Torque setting for rocker bridges is 19 foot lbs. If valvetrain is noisy, lifters or cam need replacement, unless rocker pivots are visibly worn.
Apr 24, 2009 | 1995 Jeep Cherokee
Oil not getting to back rocker, push rod clear. had a new head gasket put on, pulled head to see if it was put on backwards, it was not. how do you replace lifter.
Since you already have had it apart, you know at what point you can see the lifter. Lifter pulls straight up out of its bore, new one drops right in. If cam contact surface is worn concave, you need to replace cam as well. Always use assembly lube on lifter/cam contact surface when installing.
Apr 23, 2009 | 1990 Chevrolet S 10 4WD
Baby Gear Logo
26 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
