Question about SanDisk Sansa e260 MP3 Player
Mp3 my sansa mp3 player got stepped on and the light wont turn off My daughter's Sansa just stops working... couldn't shut it off or restart it...
    Problem Solver:
  • 8 Answers
Have you tried holding the power button down for about 30-60 seconds? It should power off itself off. You should be able to then power it back on and it work normally.
You might try a firmware update on your daughter's. Look at solution 4 here: http://www.fixya.com/support/t131894-format_sansa_e250
I works for any Sansa e series.
Posted on Feb 27, 2008
My sansa fuze has frozen, and wont turn off, or go to any of my music, and wont play anything. how do i fix it?
Try to take battery out and put it back in again that would shut the hole thing down and restart it.sounds like you have a corrupt file on your player
Mar 24, 2010 | SanDisk Sansa e250 MP3 Player
My sansa wont turn on
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater.
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
this is their instructions not mine, but i hope this helps you.
Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
Mp3 wont turn on
Make sure the hold/lock is not engaged.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 08, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 keeps shutting down
switch the usb mode which ever one is highlighted first chose the other and then it will stop refreshing
Feb 19, 2009 | SanDisk Sansa e200 MP3 Player
Sansa clip 2gb wont charge when i plug into pc. i go into my computer and it wont recognise it. the screen lights up and says connected and acts like its charging ie the battery indicator flashes but after...
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
Nov 06, 2008 | SanDisk Sansa Clip MP3 Player
Mp3
-Tha Mp3 Doctor
Sep 01, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip shutdown
-Tha Mp3 Doctor
May 20, 2008 | SanDisk Sansa Clip MP3 Player
Sansa wont charge
-Tha Mp3 Doctor
May 17, 2008 | SanDisk Sansa c200 MP3 Player
Wont turn on
Probably needs replacing, but you can try these common software fixes
-Tha Mp3 Doctor
Jun 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
110 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
