Question about Panasonic KX-TG1033S Cordless Phone
Cordless telephone trying to edit phone number by removing the 1 for local calls so that i can use the redail key.
  • reigun Feb 28, 2008
    Phone stops operating and dont have a connection to its base. It says "No link to base, move closer and try again". Even the base phone is not working as well.
    Thanks!
  • Anonymous Jan 20, 2009
    when some one calls my phone there is a one indicating it is a local call but when i want to redile the number it says i don`t need the 1 before the number to dial it. is there a way to take the 1 away from the phone number indicated on the phone.
Can't change ringer tone on kx-tg1033s unable to find help in opperating instructions
Posted on Feb 26, 2008
How do I unblock a phone number
You can find the procedure in the programming section of the manual. Look for "Viewing/editing/erasing call block numbers" The Panasonic KX-TGEA20 model number crosses to the additional handsets for your cordless phone, but these handsets are compatible with the TGEA-21X through the -27X series base units. If the [MENU] # code sequence is different you will have to share your exact model number.
The Quick -n- Dir(ect) answer is:
    1.[MENU] #-2-1-7
    2.<Navigator key "up/down" arrows> to "Block a single number" ? [SELECT]
    3.<Navigator key up/down arrows> to highlight/select the desired entry.
    This should offer you the choice to edit or erase, so choose...
    4.[ERASE] ? <Navigator key up/down arrow> to "Yes" to confirm your action? [SELECT]? [OFF] The number should no longer be on the "Blocked" list if you go back in and start from step 1 (above).
    If you have lost your original manual you can get a replacement from the Panasonic FTP site here:
    ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf
    V/R,
    Veg
    If a train station is where the train stops, what happens at my workstation?
    ~Author Unknown
May 05, 2016 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Phone adds #1 to local calls in caller ID
talk with your service provider
if the number 1 is placed before a local number then logically when calling that number, the number would be recognized as a local number and be charged as such
Form what you say , if the number was from a caller in a different state and the number was prefixed by say 6 then the system would recognize that as a long distance call
again talk with your service provider and if accurate contact your state governor or senator and make an issue of the law requiring the prefix number on caller id
Nov 21, 2017 | Panasonic KX-TG5439 5.8 GHz Dual Handset...
How to put in speed dial #s in 2.4 Hz Bell cordless phone
With the phone offline press MEMO. The IN USE light will flash. Enter the telephone number you want to store and press MEMO again. Then press the number key under which you want to store the telephone number. To use speed dial, press TALK, MEMO, and the number button where the telephone number is stored.
Jul 21, 2010 | Northwestern Bell 36280-1 2.4 Ghz Cordless...
Kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Sep 28, 2009 | Panasonic Lands Phones
Does the Dect 6.0 recognize when a phone number needs a 1 before the area code (1-800-.......)?   I entered some numbers with the required 1, and some without it.  All the calls went through.   In a few...
If you save from caller ID to the phone book from an out of area code number, the manual doesn't tell you that you have press the * key while the number is displayed and it will insert a 1 before the area code. Do this before trying to call from caller ID or copying the number to the phone book. I had to delete the area code stored in the global set up to get the caller the "*" feature to work for my local calls other wise it would just put a 1 in before the 7 digit number and would not work when it is store.
Jan 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
One one ring tone with incoming call..........
Make sure the ringer is on .
• Make sure the telephone line cord and power adapter are plugged in properly .
• The cordless handset may be too far from the telephone base. Move it closer to the telephone
base.
• There may be too many extension telephones on the telephone line to allow all of them to ring
simultaneously. Try unplugging some of them.
• If the other telephones in your home are having the same problem, the problem is in the wiring
or local service. Contact the local telephone company (charges may apply).
• Other electronic products can cause interference to your cordless telephone. Try installing your
telephone as far away as possible from the following electronic devices: wireless routers, radios,
radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors,
televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
• Test a working telephone at the telephone jack. If another telephone has the same problem, the
problem is in the telephone jack. Contact your local telephone company (charges may apply).
• The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
• Remove and re-insert the battery and place the cordless handset in the telephone base.
• Wait for the cordless handset to synchronize with the telephone base. Allow up to one minute
for this to take place.
for more info download this http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i3.pdf
Apr 01, 2008 | Vtech Cordless 6041 Phone
2.4GHz Cordless Phone
just edit the programmed phone number.
select it from your list and then press the edit button beneath the display
Jan 11, 2008 | Uniden Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
81 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
