Question about Sony Ericsson W700i Cellular Phone
Camera keeps switching to camera mode even if shutter isnt open
  • 1 more comment
  • Bicchoo Mar 23, 2008
    My w700i is constantly switching to camera mode even when the shutter is closed
  • Tanveer101 Apr 30, 2008
    I also have the same problem in my w700i.. I upgraded w700i software but still the problem isn't resolve.
  • Anonymous Sep 12, 2008
    hey I also have same problem.. new software is not solving the problem.
  • 30 Answers
Need to check housing.maybe some of part inside the housing had broken or not in good position.
Posted on Jun 22, 2008
Shutter will open but not close
Sounds like the camera is not getting battery current, since that is how it will act without batteries. Does the meter needle respond to changing light when switched on? If not, check battery polarity -- the + end touches the strip at the bottom of the battery compartment, the - end touches the battery cap. If that all checks out right, one of the wires connecting the battery compartment to the innards may be corroded or loose.
Sep 01, 2013 | Nikon FE 35mm SLR Camera
I just wanna know how to keep the apature open on my fugi s7000 so I can
First of all, it's the shutter you want to keep open. You'll probably want the aperture stopped down at least partway, especially for the longer exposures.
Set the mode dial to "M". Turn the command dial to set the shutter speed to "B". The bulb setting leaves the shutter open as long as the shutter button is held down, or fifteen seconds, whichever comes first. Unfortunately, that fifteen-second limit is much too short for good star trails. This is a limitation of the camera; there's nothing you can do about it.
This is a common problem with point&shoot cameras, even the advanced models. They're okay for 98% of the photographic situations you might encounter. But for the other 2% they either can't do it at all or make you go through hoops to do it. Just about every DSLR has a bulb mode that keeps the shutter open as long as you hold down the button (or better, yet, between two presses on a remote control unit so you don't even have to touch the camera), or until the batteries run out (and in those cases you can use auxiliary battery packs or just plug the camera into line power).
Apr 27, 2012 | Fuji FinePix S7000 Digital Camera
I want to take star photos, how do I keep the apiture open (with a shutter cable) I tried but it doesnt stay open!
My samsung BL103 camera takes good pics inside but ot outside. how do i fix
First make sure that you are in "Automatic" mode, and not in one of the camera's othe manual modes which may keep the shutter open for an extended period. But if you are indeed in auto mode, and it's still doing this, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 09, 2011 | Samsung BL103 Digital Camera
My DSC-S750 is switching on and can see the old images on the LCD. The problem is cann't any new snaps because nothing on the LCD, made attempt even though lcd is black, still those images are blank...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 02, 2011 | Cameras
My camera keeps asking me to turn it off and back on again.
Start your camera to preview mode, not using the "on switch" Use the dial to set it to ISO selection, start it , IT should work, Now when your shutter is open see if it is dirty, If yes clean it, Now turn it off , And slightly press AROUND the lens shutter, "NOT ON THE SHUTTER", AND try if that solves the problem, I solved the same problem with my DSC-W55 like that only,
Mar 12, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Is it possible to achieve a 20sec shutter release via remote control
With or without the remote control, in the M exposure mode you can select the bulb/time setting. Without the remote, this opens the shutter when you press the shutter release and holds it open while you keep the shutter release pressed. With the remote, this opens the shutter when you press the button on the remote and keeps it open until you press the button again. This allows you to keep the shutter open for up to 10 minutes.
Nov 29, 2010 | Nikon Coolpix 8800 Digital Camera
How to switch off the flash in Canon Power Shot A510
in the take picture mode, press the button that has an image of the flash on it (the top of the circle) on the right, and keep pressing it until you've selected the image that shows the flash crossed out.
Mar 27, 2010 | Canon PowerShot A510 Digital Camera
The camera shutter is always open
Plecs can you send me k750i Camera solution (with photos)
Oct 28, 2008 | Sony Ericsson K750
Sony Ericsson W700i Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
