Question about Dishwashers
Fisher and paykel dish washer ..soft touch.. will not work when switched on --comes up with a f/1 and will not startup
Called in a dish washer guy to fix it ..
Posted on Feb 27, 2008
What can I do about the dirty pool of water in the strain basket for my Fisher and Paykel dish washer
clean the strainer out and run a flush /clean cycle through the machine
use quality dish washer detergent and not cheap stuff
Nov 28, 2015 | Fisher and Paykel Dishwashers
How to use the soft touch instructions on the 913T fishers and paykel dish washer
google make,model.manual or ask landlord where manual is
Mar 17, 2015 | Dishwashers
Fisher and paykel soft touch dish washer, motor is running, but no water coming through, no kinks in hose
I have Fisher paykel dish washer hardley use but now says motor problem F2 call for service anything I can do first
Nov 26, 2010 | Fisher and Paykel Dishwashers
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Th dish washer that we have is the 2draw dd-603m
A lot depends on how it happened. Is this a new installation or everything was working well until now? F1 error implies the float switch in the drawers is activated as the inlet water soneloid could not turn off. This prevents the units from being flooded.
Are you using the correct pressure setting for the water supply. Check the user manual for details. IF you don't have one, download from the fisher & paykel website.
Nov 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel Soft Touch
Un plug the dishwasher and plug it back in.This may re set a bad control board.
May 26, 2008 | Dishwashers
Dishwashers Logo
128 people viewed this question
Top Dishwashers Experts
