Question about Tomtom ONE GPS Receiver
Max. Mem. Card
What is the maximum addressable external memory (SD card) on the TomTom One 3rd Edition device.
  • 112 Answers
I think you will find that the tomtom one 3rd edition is a sealed unit.
No SD slot.
But it does have 1GB of RAM for storage and 32MB RAM for system use.
Pretty much the same internal architecture as an early handheld PC.
All updates are done through USB.
Hope this information is useful.
Posted on Feb 27, 2008
Can I down load from my iPad onto my tomtom
No.
ipad does not have sdcard or micro-SD card slot to transfer to external device.
Verify what type of memory is used on your Tomtom Start 25.
Also verify the max capacity and speed supported.
Prefer a laptop with sdcard carrier with micro-SD to download and transfer file physically or download to pc and transfer via usb cable. See page 95 of the attached manual
http://download.tomtom.com/open/manuals/non-LIVE/refman/TomTom-EU-non-LIVE-RG-en-gb.pdf
Apr 22, 2016 | Tomtom Start 25 Europe Traffic Automobile...
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Tomtom One 3rd Edition Map downloads
Some versions of the TomTom ONE 3rd Edition have limited internal memory(no memory card slot).
connect your device to TomTom Home to check how much memory you have available and check the map is not too big for the internal memory
Mar 24, 2009 | Tomtom ONE 3rd Edition GPS
Maximum SD card size for TomTom ONE XL
The XLS which is not that much different and supports 4Gb as used in mine which allows me to keep maps of the US,Canada, UK, and the whole of europe on it and swap at will. I bought a cheap generic one. I do kow that those cards that use micro sd can and do have problems so best to avoid the micro type unless your device takes those specifically
Nov 29, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE 3RD EDITION
I have seen this before on my TomTom as well.
Do you have a backup save? The was I fixed this was to plug a 1Gig SD card into a card reader (not the TomTom) and copy the backup file directly to the card and then plug in into the TomTom while turned off and then powered it on.
if you do have a backup, you should be able to find it under you My Documents folder under the TomTom folder.
Mar 29, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
Tomtom One 3rd edition - no SD slot and not enough memory
You could probably just manually delete the Canada/USA maps from the device, and copy over the europe (or whichever ones you need) to the device.
Just plug it in, and view the memory like a normal usb drive..delete the old, copy over the new.
Don't forget to use tomtom home to backup your gps device to your computer first (thus saving your canada maps for later..)
Afterwards, you would probably have to go into your preferences and choose the europe maps.
Jan 11, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
151 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
