Question about Sony VAIO VGN-N130G/W Notebook
Sony vaio Adopter is beeps when i connect to power supply
I have sony n series adoptor the thing is when ever i want to charge it beeps and makes sound from adoptor and it wont charge can u guys plzzzzzzhelp me
  • 100 Answers
I think ur adapter have some problem.Better to change ur laptop adapter and check it.whether it give same problem.Then please contact nearest service center.
Thanks
Posted on Feb 27, 2008
My sony vaio eb (e series) wont turn on, the power button flashes green! PLEASE HELP!
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Sep 24, 2012 | Sony VAIO EB Series White Notebook...
Sony VAIO VPCEC3DFX/BJ Overheating and Power is getting off
change your adaptor with another adoptor and watch is this again happen
May 22, 2012 | Sony Computers & Internet
Vaio pcg671l lost external power (no problem for the power supply cord, work well wit battery). I am looking for a compatible docking station as external power instead.
hi
hi. I would like to suggest you get these parts are offline, because it's easy for you to test before buying {make sure you match the parts before buying}
regards
May 15, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
My VAIO doesnt seem to charge up when connected to the power supply button at times it works then power depletes very quickly.
How long did your Sony VAIO battery been used? Li-ion battery's life is about 2 years. And you can do a battery capacity correction by your VAIO's Battery management software and to see that if the problem get better. else you need a new Sony VAIO battery.
May 03, 2011 | Sony VAIO VGN-NS135E/S Notebook PC
I get the message ''Battery Low'' if I have connected the SONY VAIO to a ower supply
If you connect a Sony Vaio to a power supply, and the screen says 'Battery Low' on the lower right hand corner, and it does not go away over several hours of charging, then it could be a bad battery that needs to be replaced.
Jul 11, 2010 | Battery Technology for Sony Vaio FXA...
The only thing works on my 600 series is fan-nothing to screen
You can try reseating the memory and video card. You just pull them out and put them back in. Disconnect the power cord before. Also, the machine should beep. Those beep codes have diagnostic meanings. Listen to the beep, and google it: like 2 short 1 long or 4 short.
If the machine doesn't beep, the motherboard is bad.
Apr 22, 2010 | Sony VAIO PCV-W600G PC Desktop
No power to my Sony Vaio RX380ds. Already replaced power supply.
disconnect the power adoptor and remove the battery and hold down the power button for 10sec and than connect everything back again and that should work
Feb 20, 2009 | Sony VAIO PCV-RX380DS PC Desktop
My sony vio is not starting up
Hi there, This my indicate quite a few hardware issues but to start,
If you have an expansion card requires its own molex connection to the power supply this may be the problem if the card isn't getting enough power or is unplugged. check and make sure all power cords are plugged in and not coming loose on the mobo and all other components, If you have access to another Power supply try swapping your power supply for a different one. i hope this helps and good luck.
Jan 16, 2009 | Sony VAIO PCV-RX753 PC Desktop
DC port?
check adopter may be replace with any other laptop adopter....
May 04, 2008 | Sony VAIO GRX520 Notebook
Sony VAIO VGN-N130G/W Notebook Logo
244 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
