Question about Samsung 80GB INTERNAL 3.5- IN SATA HDD 7200RPM 8MB 1- IN HEIGHT 3- YEAR WARR. BULK (SP0802C) Hard Drive
Cant able to format HD
I have samsung 80GB hd
i cant able to reinstall xp after inserting xp cd
  • 1 more comment
  • ap123 Feb 26, 2008
    i have samsung 80GB hd
    hai
  • Joseph Danko May 11, 2010
    Does your Windows XP system come up at all?
    If you can get the F8 menu up can you boot "SAFE MODE"?
    If SAFE MODE works you should be able to run SETUP from the CD.
    If your Windows XP CD is bootable you should see the message
    "Press a key to boot from CD" right after you boot the PC with the CD in place.
    President:
  • 2,351 Answers
To re-install XP over it's self. Put the CD in your cdrom drive. Start the system & press the F5 key every 2 seconds. This will load a boot menue. Using your keyboards up & down arrow keys highlit the cdrom drive & press enter. You will see to boot to the cd press any key, press the space bar. XP will start to load. Choose the correct options for a re-install.
Enjoy!
please vote...
Posted on Feb 27, 2008
How do you backup, format and reinstall the OS from disc?
Hi, Back up your internal HD to an externa; drive using something like CarbonCopy Cloner or SuperDuper or even make a disc image of it onto the external drive.Insert your installation disc and restart the computer while holding down the C key. After a while you shoulod get the usual start=up signs and you can let go of the C.The Mac should thenm be starting from the CD/DVD and you will get a welcome to mac OS screen asking you what language yu want to work in. Choose whichever and then follow the instructions that appear on screen. Remember though, when you format, everything will be wiped from the HD.
Mar 23, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
Jun 11, 2010 | eMachines (ET181001) (A1803181 ON) PC...
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Hard Drive Prevents any other windows device from loading
Hi, Mark Here.
Yes the setup on the xp install puts drivers into memory, but being an older version of windows B4 sta was out it does not have drivers to support it.
You could go to Microsoft & search for a new version of setup install drivers that includes sta, & download to thumb.
Really typical Windows Failure (driver not available freeze up or blue screen).
Mar 22, 2009 | Computers & Internet
I cant install windows xp because of... i dont know!
Here is what you should do, go to a computer store and buy a 40G HD. Try installing on that. It could be the size, but most likly not. Im going to guess and say take a look at the bottom of your reinstall disk. If it has any scratches, there is your problem. NTLDR is your boot sector on you HD.
Mar 04, 2009 | Intel Motherboard
Cant play certain games in my sata hd 160gb.
I suppose Hardisk has no problem if its sata or IDE ,games will mostly be Graphics and Processor oriented and also to do with the RAM. Should be some other problem . give me more specific problem you face.
Dec 20, 2008 | Microsoft Windows XP Home Edition
Samsung 80GB INTERNAL 3.5- IN SATA HDD 7200RPM 8MB 1- IN HEIGHT 3- YEAR WARR. BULK (SP0802C) Hard Drive Logo
143 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
