Question about Brother IntelliFAX 5750e Laser Fax
NG: POOR LINE CONDITION / OUT OF MEMORY
We have multiple faxes in our facility that produce the above error message when trying to submit faxes and we are also unable to receive faxes. I tried using a phone to test the connection and the line worked, but I was thinking there may be some static issues that could cause this problem. Does anyone have a suggestion for troubleshooting?
  • 5 Answers
You can adjust the Compatibility mode. This adjusts the sensitivity of the machine to interference on the phone line by lowering the transmission speed:
a. Press Menu, 2 (Fax), 0 (Miscellaneous), 1 (Compatibility)
b. Press Up or Down arrow to select "Basic"
c. Press OK.
d. Press Stop/Exit.
e. Try resending the fax.
If the problem continues we recommend you try the unit on another line at the current location or another location. Always restart your machines after you made changes, that way you will see the results.
Posted on Oct 20, 2009
  • mfraze01 Jan 14, 2011
    If everything is plugged in correctly and you have a dial tone, hear the ring, the destination answers and you still get this message. THIS SOLUTION WORKS. Thanks
  • Mel Fo
    Mel Fo Oct 10, 2013
    Worked for me!!! Genius. A million TY's
    New Friend:
  • 120 Answers
If you hear static you need the phone company to check it out. This will cause problems receiving and sending faxes. Lawrence
Posted on Feb 27, 2008
    Scholar:
  • 159 Answers
The out of memory condition is reached due to not being able to send faxes from memory. Have the phone company check the lines, but 1st make sure there is nothing hooked into the phone lines such as burglar alarms that canintroduce noise and static.
This sounds stupid but....make sure the phone line is set up in the right input.
the phone worked on mine but i got the error "NG POOR LINE QUALITY / OUT OF MEMORY". switched the phone line input(from the telephone) and the phone cord output and it works fine now
Posted on Jun 09, 2008
Why can it only send one page fax?
This is usually caused by interference on the telephone line. Try a different telephone cord to the wall or try connecting it to a different wall jack to narrow down the cause.
Mar 31, 2016 | Brother MFC 8820D All-In-One Laser Printer
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
My Brother mfc-665cw will not fax. It keep saying NG: POOR LINE CONDITION/OUT OF MEMORY
Check to see if you can make a call using the fax machine. This error can occur if you have no connection. It can also occur if your line is occupied or busy.
Oct 14, 2010 | Brother IntelliFAX 5750e Laser Fax
It shows up NG: Poor Line Condition/out of memory
I had the same problem with a MFC9840cdw I called Brother and they did not help much so I played Around with the settings and until I came to line detection it was off i changed it to on and now it works perfectly fine
Jul 21, 2009 | Brother Office Equipment & Supplies
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 5750e Laser Fax Logo
24,734 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
