If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3115 (or RX3715) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Im having same problem as bexta27783.I also cant access the music I download to my Nashi. I have a...
(More)
Im having same problem as bexta27783.I also cant access the music I download to my Nashi. I have a utilities disc and it doesn't work. What am I supposed to do with it?
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a...
(More)
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a reboot, the initial screen appeared, then it frozed and then it just went blank. The battery was fine but the iPAQ just won´t turn on. I returned home and immediately plugged the AC charger and nothing happened. Something similar happened a couple of weeks ago while I was outta my house and as soon as I returned home I plugged the AC charger and the LED that indicates "battery charging" started blinking, so it worked that time, but today it just does not work.
What can I do? I had a lot of stuff there that I need to access...urgently. Please help. Thanks a lot.
