Question about Garmin GPSMAP 60CSx
Garmin Nuvi 650
I have an enabling Bluetooth screen and I can't get rid of it. I have tried turning off the unit and have had no success.
  • d1ML Feb 26, 2008
    I found a much more simple solution. Simply raise the Satellite Antenna and press reset - Done and you start all over.
  • 35 Answers
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Posted on Feb 26, 2008
  • Kenneth  Keaton
    Kenneth Keaton Feb 26, 2008
    This Fix origionally created by silentspoon a FixYa Guru.
How do I connect a plantronics headset to an NEC DT700 series phone
You can transfer photos from your nokia lumia 928 to laptop wirelessly or wired. Wired transfer is the easiest way when your unit comes with the data cable and the software. Now, if the software is not inclusive you can set your CP's connection settings "Connected as USB memory" however you may have difficulties in viewing since the connection layer platform is not capable of viewing the pictures or images but you can view later after you copied it on your laptop. Now, if your unit doesn't come with data cable and software either you can use the BLUETOOTH connection by simply turning or enabling both Bluetooth device on your laptop and cp which can be found in settings usually, once enabled and set visible you will noticed both devices sees each other with their name if not try to search manually by pressing search and chose paired bluetooth device with confirmed access code or id. Right then, when connection is successful you can start copying pics or images to your laptop. (Make sure you know the directory your pics are being copied, it is usually saved in bluetooth download images directory or other directory, pls manage to locate). Thanks hope this helps... Goodluck.
Oct 08, 2014 | Plantronics Radio Communications
Pair iphone to general motors car
  • Get into your GM vehicle with your Bluetooth compatible cell phone and turn both on. Use the dashboard controls to turn your GM's Bluetooth system to its "Discovery Mode."
  • 2 Go to the Bluetooth application on your phone and turn the Bluetooth mode on to its "Discovery Mode." Now your phone will begin searching for other Bluetooth devices within its range. When it locates your GM's Bluetooth, your phone's screen will show the name of your vehicle and ask if you'd like to continue syncing the two Bluetooth devices. Select "Yes."
  • 3 Enter the numeric code that appears on your GM control panel screen into your phone and continue the pairing process. While pairing, your phone will share your contact information with your GM to enable the Caller ID on the dash screen to work.
  • 4 Confirm successful pairing by making a phone call. Make calls using your GM's voice activation, which is done by pushing the "Phone" button on your steering wheel. You can also dial from your phone's keypad and the sound will transfer to your GM's speakers.
  • Jan 23, 2014 | Apple iPhone 5
    Ipad and beikin keyboard
    You will need to enable bluetooth on your iPad and then pair the keyboard to the iPad. Try the following:
    • On your iPad, tap the settings icon from the Home Screen.
    • Tap on General.
    • Tap on Bluetooth.
    • Toggle Bluetooth to On
    • Turn on the Belkin keyboard.
    • The keyboard will show up under Devices on the iPad.
      Select Belkin Bluetooth Keyboard.
    • A code will appear on the screen.
      Enter this code on the keyboard and click Enter.
    A message will pop up when pairing is successful. If pairing fails, repeat the steps above. If you're still unable to pair the two leave a comment and I will help further troubleshoot.
    Hope that helps!
    Jan 15, 2014 | YouTube Videos
    Sharper image freedom Bluetooth model number ESI-P400 how to put in pairing mode.
    To pair your device with The Sharper Image Freedom:
    1. Make sure your device has Bluetooth capability.
    2. Slide the POWER switch to turn on the Freedom, indicator will begin to flash.
    3. Follow the instructions of your device to pair the unit.
    4. Pair your device with the unit by selecting FREEDOM from your Bluetooth listings on your device or selecting YES. If prompted, enter "0000" as the passcode.
    5. Press play on your device and use controls on the unit to adjust desired volume.
    Note: Once you have successfully paired your device, you typically will not need to repeat the above steps. Please ensure the Line-In cable is unplugged, the unit source is set to Bluetooth and your device has Bluetooth enabled.
    Note: The effective Bluetooth range of the Freedom is approximately 30 feet.
    Nov 19, 2013 | Radio Communications
    Sharper image freedom Bluetooth speaker model ESI-P400 discovery mode button sequence
    My Lenovo B460 cannot detect bluetooth peripheral device. i have searched online for updated device but not successfully. Please help me. Many thanks
    Hi thanhloan88h,
    There are some reasons why Bluetooth of your system wont detect any Bluetooth peripheral device. It might be that the Bluetooth is not enabled or there's a missing driver. You may try to enable the bluetooth by pressing the FN+F5. For the bluetooth driver update, please follow the instructions below.
    1. First, go to this link to download the latest Bluetooth driver.
    2. On that page look for Bluetooth.
    3. Ensure that you will download the driver that corresponds to your operating system.
    4. Try to save the .exe file to your desktop. Install it then restart your computer.
    5. After rebooting, try to press the FN+F5 to enable the bluetooth.
    Hope it helps.
    Thank you for using FixYa.
    Oct 16, 2010 | Computers & Internet
    Help - pc doesnt detect my blue-tooth enabled cellphone!!!
    Go to Windows update or update your software and driver from the items website..
    Jun 01, 2008 | Billionton (GUBTCR41ABT) Wireless Adapter
    Garmin NUVI 660 BlueTooth
    I had the same problem, and this is how I fixed it. Now it's working fine.
    Thank you for contacting Garmin International,
    If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
    1. Power the unit on
    2. Touch View Map
    3. Touch the ETA/Speed button in the bottom left hand corner.
    4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
    5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
    6. Touch UPDT P, then Touch yes.
    7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
    Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
    Garmin Nuvi 660 - Bluetooth
    I fix this problem for my Nuvi 660 Europe. I found resources in Italian language only: 1 - go to http://www.garmin.it 2 - in the search texbotx (i the up left corner of the page) type bluetooth and press enter 3 - click on the 1st faq that will appear 4 - download the file FileBluetooth.zip 5 - unzip the file 6 - copy 006B055301.GCD in X:\Garmin\RemoteSW directory 7 - reboot your nuvi At this poin bluettoth would be ok newly. Bye
    Aug 08, 2007 | Garmin Nuvi 660 GPS Receiver
    Garmin GPSMAP 60CSx Logo
    427 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Steve
    Will Halftowaite
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
