Question about Magnum OmegaForce S45 CB Radio
Magnum omega force s45 cuts out
Hopefully someone can help me. My magnum omega farce cuts in and out on me when using an amp......HELP
  • smokey518 Feb 27, 2008
    I run this set-up in my mobile with a 2x8 pill amp. I have a 250 amp alternator powering 3 batteries. everything is grounded correctly and I run a Predator 10-k antenna with the thick coax. The Magnum is adjustable from a 1 watt to a 10 watt dead key and swings to around 45 watts. I have a Galaxy 93T that has a 2290 for a final. This radio swings to almost 80 watts with a 4 watt dead key and it works great with the amp.
    I'm wondering if the mosfet finals in the magnum are causing the problem.........I don't know. But I do know power is not an issue because the Galaxy swings higher with no problem. Thank-you for your response......I think I'll sell the Magnum and buy another Galaxy.
  • Dean Dishman May 11, 2010
    what kind of amp are you using?? Is the magnum stock? whats your dead key? Most amps work best with a 1 to 4 watt dead key if its pushing more than that your probably over driving the amp causing it to shut down.So more than likely youll have to reduce the dead key and that should cure your problem.Looking at the specs on this radio stock on AM it averages 9 Watts RMS and 40 PEP so its probably overdriving the amp. are you using this radio for a base or mobile application? This radio by its self draws 7 amps max. Let me know what you find....Dean
Too much wattage for a 2x8, those are 4watt input max, and wouldnt push more than 20pep maybe the dave mades can take a little more abuse. but certainly not 80watt pep into a two pull driver. for both of thoer radios i would suggest a high drive. btw, i love my Omega Force. I think your problem is the mostfets are near shorting out on those two driver pills.
RiFFRaFF
Posted on Oct 11, 2008
He said he can adjust his carrier from 1-10 watts. Which is stock. I have an S45 as well, I run it at about 3watts swinging to 30 into a 2x2290 all the time that drives a dave made 4x2879HD. Sounds like you have about the same setup as mine with your 2x4pill. Try turn down (or have it done) your max peak power for both am/fm and ssb to max of 30att and see what happens.
Posted on May 02, 2008
  • 37 Answers
Im a Galaxy man myself and I swear by them .Looks like youve got more than enough power. The mosfets shouldnt have any effect that I recall but be aware that most new C B Radios are going to Mosfets Galaxy being one of them' because of transistors like the 2290 being hard to find and expensive. $20 + a pop.
Posted on Feb 27, 2008
I have a magnum omega s 45 hp that goes into hyper scan what can i do
Hi don,
Hyperscan is usually, but not the only domain of scanning receivers.
Does it affect your Tx or Rx, if not, then there is nothing wrong, but if you want it to stop scanning for an active channel, then press the scan button once to stop it.
I hope that answers your query.
Cheers,
Peter
Feb 19, 2013 | Magnum OmegaForce S45 CB Radio
Codigos para desbloquear
  • En esta pagina es la informacion que usted solicito..
  • http://www.radioaficion.com/HamNews/mods/mods-cb/4506-magnum-omega-force-s45-mods.html
  • Espero que esto ayude.
Nov 05, 2011 | Magnum OmegaForce S45 CB Radio
Para convertir la frecuencia de 2800 29000 a 26000 27000
  • Espero que esto ayude..
My magnum omega force s45 cb radio is stuck on PA, how do I get it off this?
HI,my name is John. Try to flip the switch to CB...hope this helps...
Aug 08, 2010 | Magnum OmegaForce S45 CB Radio
How do i set a channel in the memory on my magnum omega force
Push Func button, then Mem button, then a number from 1-5...saves frequency you are on
May 24, 2010 | Magnum OmegaForce S45 CB Radio
Wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Dec 23, 2007 | Magnum OmegaForce S45 CB Radio
Mic wiring
Check this link http://www.cbtricks.com/radios/rflimited/omegaforce_s45/index.htmand download the pdf file Owners manual page 8 has the info you need...Chia
Dec 22, 2007 | Magnum OmegaForce S45 CB Radio
Radio Communications Logo
1,062 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
