Question about LG DLP Projector 1400Lum RD-JT30 Multimedia Projector
Lg 50'' dlp tv
The tv flashes an orange light then makes a hissing noise INSIDE the tv an goes back to red light(standby).pls help me.
  • ginno Dec 20, 2008
    same remote to switch on light goes red to orange, hissing behind set then orange light flashes and returns to red. No picture no sound
  • KittyStump Mar 25, 2009
    I have the same problem. I have replaced the lamp and thinking about changing out the fuse as well.
    did you find a solution?
Hi my is the same do you have a solution yet?
Posted on Mar 28, 2008
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
When you switch on the tv it goes to standby mode, and when you press standby it turns on to a orange light then goes back to a red light, any idea whay this is happening ....
My Westinghouse LCD tv has the same lights on it It goes orange or red when there is no signal from that source... or while it is calibrating itself to the new frequency etc.
Oct 19, 2013 | LG 42PM3MV 42 in. PLASMA TV
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture no sound loud humming sound for a short period when you turn it on than a orange light flashing at bottom where the blue light is when you turn it on.
AV cables reversed perhaps. Sounds like VIDEO (Yellow, Green, Blue or Red) cable is plugged into the AUDIO section. Perhaps you have switched the RED (Left audio) cable plugged into the RED (Component) Video cables. This would account for the loud buzz and since the set isn't getting an image it goes into standby mode. Just a thought.
Nov 25, 2010 | HP Pavilion MD5020N 50" DLP HDTV
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
Mar 04, 2009 | LG RU-44SZ51D 44" Rear Projection...
Tv help
This is bad. You need to either be under warranty on these big screen TVs or get the service manual. Especially since this is an off brand.
Jan 01, 2008 | Televison & Video
280 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
Lawrence Oravetz
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
