Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Receive a black copy
Whenever I fax a paper, I get a black copy out of the fax.
I tried to reset the contrast, but it did't work or maybe I did it wrong.
Can somebody help me?
  • brenpff Feb 27, 2008
    The copies that I receive from others are fine.
    Only when I copy a paper or when I fax something, the OK-paper is black.
  • GuestTech May 11, 2010
    How are your received copies? (Faxes from other machines)
  • 31 Answers
Try this for uf490 and 4100
press function 7 monitor monitor monitor monitor *
you will enter service mode
press arrow down then locate for DIAGNOSTIC
PRESS START
press arrow down then locate for ADJUST SHADING
PREPARE A CLEAN SHEET OF PAPER AND PLACE IT TO WHERE YOU ARE PLACING THE DOCUMENTS BEING FAX
THE PRESS START
AFTER THE UNIT SCANS CLEAN BOND PAPER, PRESS STOP STOP STOP
THEN TEST COPY.
CALL US AT 3633636 FOR more assistance
Pantronics International Corporation
51-53 Gen Rosendo Simon st. Caloocan City Manila
Posted on Mar 11, 2008
  • 33 Answers
Problem could be with static discharging into CIS as paper runs through adf, was a common fault and there is a set of discharge brushes you can get to fix it or... unplug it, open adf and go over it all gently wit a cotton rag, leave it for about 5 mins then turn it on again
Posted on Mar 06, 2008
    New Friend:
  • 120 Answers
Scanner problem. if you receive faxes that are good. the scanner is used when you copy or send. Lawrence
Posted on Feb 27, 2008
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Fax received is all black
try and make a copy how does it come out? if black the poblem is most likely the thin strip of glass, it's either dirty or not working
Dec 12, 2007 | Brother IntelliFAX 2800 Laser Fax
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
154 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
