Half a picture horizontally
I have a phillips 33" large tv ( not widescreen or flat ) and theres only half a picture. It was flickering to a full picture but now its stays just half a pic???
  • 979 Answers
High voltage reg and or capacitance issues...accordianman
Posted on Feb 26, 2008
Phillips flat screen tv left half of screen is black right side is dim and flickering
Is your tv less than a year old? You need to call Phillips and see if it is covered under warranty. If that is not the case you need to get a few estimates. You want to know if it will be cheaper to repair or replace your tv set.
1 888-744-5477 Phillips customer service number
Aug 14, 2016 | Televison & Video
Horizontal is flickering
flickering as the picture becomes smaller and bigger or are there lines showing up? Please describe it better if you can so I know exactly what you are seeing. Any color changes?
Jun 28, 2008 | iLO LCT32HA36 Television
Red noise or flicker on bottom half a plasma screen
Hi!
as i see your picture maybe that is lack of vertical sync or vertical ramp... can you send me the service manual then i diagnose this problem. send me at gmf_likha@yahoo.com
Nov 08, 2007 | Televison & Video
Samsung tv has flickering lineswhile watching tv
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec How to Fix Samsung TV Flickering Blinks Flashing Flat Screen ... Rating is available when the video has been rented. ... sorry to bother you tampatec but i have a RCA tv it works great when it's.... My Toshiba Full HD led tv model 32PT200ZE is having issues of screen blinking/flashing and horizontal lines.
Sep 25, 2015 | Samsung Televison & Video
42 inch Phillips LCD TV turns itself off after only a minute or two no flashing light
I had the same problem for 3 days. Remove all inputs to the TV and turn it on again. If it stays on for any length of time you're half way there. While the TV is on, go to the picture format menu and change it from automatic to widescreen. This worked well in my case, but still think there may be an underlying problem with the input circuit. Good luck!
Dec 20, 2010 | Philips Televison & Video
We have a roughly 10 yr old tv that was given to us from friends (therefore we dont have waranty), and it has just started flickering red lines horizontally across the screen. It is a large non-flat rear...
Ur convergence is dead.These problems are colors misalines,3D pictures,colors distorted.U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 16, 2010 | Televison & Video
I have a 55 inch visio lcd tv and the top of the screen flickers on certain tv programs. Is it the tv or the program itself? I have not seen this problem on smaller screens. When the program is in hd full...
The same way you adjust your PC monitor screen; you can adjust your Visio TV. Menu button will get you into the settings and you will go to picture--then "More" --there you will find vert and horizontal adjustments...find the right one for you.
Oct 19, 2009 | Vizio VF550M 55 in. LCD HDTV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
