Question about Belkin (F5D7230-4) Router (587009)
Router cant b found
I have a belkin F5D7230-4 model i recently tried to reconfigure the router and inadvertently press the wrong command button, i cant remember what button it was but since then, when i try to access the router the browser tells me the connection was refused, or the connection times out. I have tried to reinstall the router but when the setup disc searches for the router connection, it cannot be found. Oddly my computer can still receive an internet connection through the router but my x-box 360 cannot, the x-box is the reason i bought the router
  • 112 Answers
Locate the reset button on the rear of the router.
Should be below the antenna and recessed use a paper clip or similar to hold in for 10 secs.
This will reset the router back to factory defaults.
Type in 192.168.2.1 into your browser and you should get the routers setup page. Click the login button, no password is required. You can set this up yourself once in the router setup.
Be aware this router is NOT on the Xbox live supported list.
Check link below for supported Live Routers.
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
If you have only bought thi recently get it swapped out if you cannot connect to live once reset.
Let me know how you get on.
Posted on Feb 26, 2008
  • Geoff Champion
    Geoff Champion Feb 26, 2008
    Just a small note.
    Disable firewall in your operating system and use the one on the router.
    You will have a lot less issues with your network.
Cannot locate password on my router model F5D8635--4vI
Reset the Belkin to default settings and reconfigure SSID and Security Key(password). User manual can be found here: http://www.belkin.com/support/dl/pm00781ea-usermanual_uk.pdf
Jan 23, 2013 | Belkin Computers & Internet
My belkin G+ wireless router model: F5D9231-4 v2 security is lock and i cant log into my laptop
If you have forgotten the password, reset the Belkin by pushing and holding the reset button for 30 seconds or so and release, this will reset to default settings. Connect and reconfigure the SSID and Security Key. You may want to write down the password and store for future use. Belkin Support: http://www.belkin.com/us/support-article?rnId=6939
Dec 27, 2012 | Belkin (F5D7231-4) Wireless Router
My daughter locked our router a belkin g wireless and forgot the password how do i fix it
Reset the router, push something into the reset hole on the back of the router for 20 seconds or so
Aug 15, 2010 | Belkin (F5D7230-4) Router (587009)
I changed the security settings on the router and there the wrong settings for my computer and now i cant connect to the router to change the settings
if you can no longer connect to your router, the only thing to regain access to it and reconfigure is to manually reset it to default settings. To do this, you need to press the reset button/switch (or some models have dip pins hidden in a small hole) for 30 seconds while the router is turned ON. After 30 seconds, release the button and all your previous and faulty settings will be removed. Follow the documentation packed with your router for the default user name / password to access your router's admin page.
Feb 02, 2010 | Belkin F5D7234-4 Router
Belkin F5D8638au4A modem-router. router operation
Try first to reset and reconfigure the router , to reset it press and hold the reset button of the router for 10 seconds while power is ON and then after that reconfigure the router........
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Need to re-set the security key can not remember password
Press and hold the reset button for five seconds, then release. When the Power/Ready light becomes steady again, the reset is complete. This will reset your router to the default password, which is no password (empty). It will also erase your router configuration, so you will have to reconfigure the router.
Full instruction manual for this device can be found here:
http://cache-www.belkin.com/support/dl/f5d5231-4_manual.pdf
Nov 25, 2009 | Belkin (F5D5231-4) Router
Laptop computer (wireless) will not display a web connection (internet explorer).I use a Belkin wireless G router. I have power,modem, internet, wired computer lights I recently had a virus removed...
Well as i understand.
You need to do a hard reset of your router and reconfigure your router.Then try to access your internet in case it work's good in case it not.
Then,
get in to a command propmt (run>cmd).type ipconfig
check the ip address.whether you getting a default ip address or not.if yes then, type ping any website name press enter.It will give you a turn around time that means your compuetr is communicating with your router. then try to open a website on internet Explorer. In case it not work run a small winsock.
in cmd window.
Hope this will resolve your issue.
Nov 02, 2009 | Belkin (F5D5231-4) Router
I have a belkin Router F5D7634/4 It has the power light on The wired light is on The ADSL is flashing I have followed the instructions time after time but I cant get any further thank you from John Bond
You can reset first the router and reconfigure it back , to reset it press and hold the reset button of the router for 10 seconds while power is ON and then after that reconfigure the router..........
Nov 02, 2009 | Computers & Internet
What is the default password of belkin router
The Belkin Router does not come with a factory set password or username. I phoned Belkins's 800 number today and found it out. They told me to reset the router by using a paper clip and holding down the button for ten seconds or so.
You can try password - Admin ( usually works on old models ). Make sure to keep User name Blank.
Hope i helped.
Thanks for using ' Fixya ' and have a nice day!!
Jul 14, 2009 | Belkin (F5D8231-4) Wireless Router...
How to clearing my router key password
there should be a button at the back or below your router it is very small and you need to use something pointed for it. when resetting your router, you will need to press the reset button for at least 5 seconds. once its reset you will need to reconfigure it best way is by using the cd-rom that came with it.
Feb 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7230-4) Router (587009) Logo
76 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
