Televison & Video Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hitachi 55FX48B suddenly turned off.Power light is not on.Removed back cover. No LED's lit.Unplugged power,plugged in. LED's lit up brightly momentarily then went very dull.TV did not come on. thks
Anonymous
Level 3:
  • Master 408 Answers
  • Posted on Feb 16, 2010
Anonymous
Master
Level 3:
Answers
408
Questions
6
Helped
148695
Points
1141
It could either be a fuse inside the tv near the power supply board or the power supply board is bad.
1helpful
Tv wont turn on
With set unplugged remove rear cover and follow the power cord to the fuse--good or bad? This set should also have some led lights there that are green or red---look to see if any are lit or if when plugged in with back removed which come on or go off instantly, the reason I ask is those are each tied to a voltage source and will point to where the problem MAY be.
5answers
Hitachi 55FX48B 55 in. loss of power...
Try first unplugging power cord for ten minutes, it looks more like your power unit has gone.
55 inch tv shut off will not turn on any more
velvel535, since you do get the other led's to light up it could be that you have an operable power supply and the problem is more than likely in the horizontal deflection circuit' a shorted h.o.transistor or components related to it.If the tv does have a good power supply you will hear some kind of noise when you push the power key though this is not a sure indicator of a good power supply. some repair costs for a horiz out problem can run up to 290 dolls depending on the problem.Please leave positive feedback if i answered your question.thanks!
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Hitachi model 55FX48B
Just had the exact same thing happen to me.
Wont power on
Needs Convergence amps replaced. Also fuses around this board are out. There should be small pico-fuses open around this board(replace)
Hitachi 55X48B
Do you get Led light? Open back and see if you see Diodes light, which number lights tells what is wrong with set. Most of the time on this one either sound problems or Convergence amp problems.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
