I have Toshiba DP2570 copier but user interface language is dutch and I can't change it to english because I does,t know dutch so can any one discribe how to change language
I have the same problem if there is a solution could you please feed me back at my mail ( [email protected] )I have the same problem if there is a solution could you please feed me back at my mail ( [email protected] )
You can't post conmments that contain an email address.
08-220 User interface Language displayed at power-ON
ALL EUR: 0 UC: 0 JPN: 5 <0-6> SYS 0:
08-221 User interface Language selection in UI data at Web power ON ALL EUR: 0 UC: 0 JPN: 5 <0-6>
Dear
go to COPIER > OPTION > BODY
<Adjustment method>
XXYYZZAAXX: Country (UP), YY: Language (ja), ZZ(00) Destination,
AA(00): Paper size type
The display contents conform to the display method of
(COPIER>DISPLAY>USER>LANGUAGE). Enclosed in the brackets
are defaults. The country and language are only displayed.
<Operating procedure>
1) Select <CONFIG>.
2) Select an item to reverse its display. Then press the + or - key to change
the contents.
3) Each time the + or - key is pressed, the contents change sequentially.
4) Display the intended contents at all items and press the OK key.
5) Turn the main power switch OFF and ON.
To change language: Press "Utility/Counter" Press number 2 key, then number 1, then number 1 again. This will get you to the language selection without having to read the screen. Once there select your language. If this does not correct the problem, you may have a board or Nav Ram problem and should contact someone for service.
is it windows 7 home basic?if it is the only way to change language legaly is to upgrade to ultimate as that has all the languages.there is a programme you can run but it does not change the language of the op system.eg windows 7 dutch would be changed to english but updates will still be dutch.if its ultimate download the language pack from windows update.
hello, the drivers can be downloaded from the same place which is toshiba website. Now I personally have used an english key to install a spanish version of windows xp. I dont know if this would be the case with your version.
There is no feature on the device that lets you change the language. The only way is to install English language from internet the link is given as You go on www.samsungmobile.nl
Then choose Support and Programme to download...
You have thus a list of files for languages that you can download.
download the English language
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
