Question about Sony Ericsson Walkman W810i Cellular Phone
Not displaying the screen
I have turned the phone on and all it displays is signal battery life calls and menu
  • gremleen Feb 26, 2008
    I have the same problem...
    Brigadier General:
  • 7,752 Answers
The phones need to be reflash , you can do this at your nearest mobile service center or www.topsony.com
Posted on Apr 03, 2008
How to remove the master security code for nokia mobile model No:1209 plz tel me
On the main screen type
*#06# for checking the IMEI
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Code (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically restart
May 01, 2011 | Nokia 1209 Cell Phone
Tip
Nokia secret codes
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
3. Displays (if there) the date where the phone was purchased (MMYY)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
on Jul 15, 2010 | Cell Phones
Tip
Nokia Mobile Secret Codes
On the main screen type in: *#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#67705646# This will clear the LCD display(operator logo). *#0000# To view software version. *#2820# Bluetooth device address. *#746025625# Sim clock allowed status. #pw+1234567890+1# Shows if sim have restrictions. *#92702689# - takes you to a secret menu where you may find some of the information below: 1. Displays Serial Number. 2. Displays the Month and Year of Manufacture 3. Displays (if there) the date where the phone was purchased (MMYY) 4. Displays the date of the last repair - if found (0000) 5. Shows life timer of phone (time passes since last start) *#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. *#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network. *#4720# - Half Rate Codec activation. *#4720* - Half Rate Codec deactivation. The phone will automatically restart If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538# Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345 Press *#3925538# to delete the contents and code of wallet. Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \ *#7328748263373738# resets security code. Default security code is 12345 Change closed caller group (settings >security)
on May 19, 2010 | Nokia 1100
Nokia new models secret codes
View the firmware version of the phone
Dial using the keypad: * # 0000 # - the version number displayed on the display.
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#67705646# This will clear the LCD display (operator logo).
*#2820# Blue tooth device address.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
SIM Clock
Stop allowed
Warranty Codes
* # 92702689 # [* # war0anty #]
Enter the menu of warranty codes. In fact, you do not need, but you can find them using the arrows scroll menu.
Menu:
1. Shows the serial number of the device.
2. Date and year of manufacture (eg 0299).
3. Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4. Date of last repair (if any)
5. Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
EFR CODEC (Enhanced Full Rate)
This function with its inclusion on the idea, should significantly improve the quality of speech, but unfortunately, it must be supported by your connection. When the work is slightly increased power in the phone call (about 5%). How do I know, none of the Russian cellular operators do not support this feature. Principle is based on a different compression algorithm for speech recognition (ACELP) and has a wider bandwidth.
Feb 28, 2011 | Nokia E71 Smartphone
All code sent my email
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
SimClock
SIM Clock
Stop allowed
Warranty Codes
Menu:
1.Shows the serial number of the device.
2.Date and year of manufacture (eg 0299).
3.Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4.Date of last repair (if any)
5.Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
Dial * 3370 # to activate (the phone should reboot) or # 3370 # to deactivate this function.
HR CODEC (Half Rate)
Substantially impairs the quality of speech, but saves battery somewhere at 30%. Again, must be supported by a mobile operator. American networks that support this feature, I do not know.
Dial * 4720 # to activate (the phone should reboot)
or # 4720 # to deactivate this function.
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Nokia 5230 Cell Phone
I whant learn all nokia 6300 hide code please
on the main screen type, *#06# for checking the IMEI (International Mobile Equipment Identity).
Jan 25, 2011 | Nokia 6300 Cellular Phone
I want all secret code all nokia n72
*#62209526# – Display the MAC address of the WLAN adapter. This is available only in the newer devices that
support WLAN
*#92702689# – takes you to a secret menu where you may find some of the information below:
4. Displays the date of the last repair – if found (0000)
*#3370# – Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
#3370 – (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# – Half Rate Codec activation.
#4720 – Half Rate Codec deactivation. The phone will automatically restart
Apr 08, 2010 | Nokia N72 Cellular Phone
Need programming codes for Nokia 7205
Is there a specific reason you need the code? The following are the most common nokia programming codes: On the main screen type in:
Hope this helps, Joe
Feb 19, 2010 | Nokia Intrigue 7205 Cell Phone
The wired keyboard backlight turnes off too quickly
You would need to go into the Setting Menu and find the Backlight or Power setting to lengthen the display and keypad backlight times. Just know that your battery life will decrease the higher the settings especially since it is a VGA screen.
Dec 18, 2008 | HTC Touch Pro Smartphone
W300i phone displays white screen
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
Jun 16, 2008 | Sony Ericsson W300 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
18 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
