Question about Philips DVD Micro Theater Shelf System (MCD288) System
How to play TV sound through Philips Mcd288
How do I connect the philips mcd288 so that it can play TV sound?
  • Anonymous Mar 27, 2014
    hi ,how can i connect my apple tv with my philip hts3020
    New Friend:
  • 120 Answers
You must plug the t.v. audio out cables into an audio input on the philips. left and right audio rca jacks. then you must select that input on the philips to hear the tv. Lawrence
Posted on Feb 27, 2008
How do I remove a stuck cd from a philips micro theater MCD289?
Disassemble the system to get access to the drive and remove the jammed CD.
Aug 29, 2016 | Philips MCD288/37 DVD Micro Theater System...
Unlock code for my Philips MCD 177
I need a region unlock code for my Philips Micro Theatre MCD290 DVD
Nov 17, 2008 | Philips MCD288/37 DVD Micro Theater System...
Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
Aug 08, 2008 | Philips MCD288/37 DVD Micro Theater System...
Twang
How do you connect your system?
Joe
Feb 04, 2008 | Philips DVD Micro Theater Shelf System...
Philips mcd288 mp3 albums
There's a little bit of work involved, but what you should do is to record those tracks individually as folders, then transfer those to your DVD burner...accordianman
Dec 30, 2007 | Philips DVD Micro Theater Shelf System...
Says close when i try to play my dvd.
My MCD288 developed the very same issue just 2 months after buying it. I kept thinking than my little niece had to do something with that, and only today, after 2 years decided to open it up and check. Well the problem is the GREY (not the black one) microswitch that is soldered on a little PCB atteched to the CD/DVD mechanism. You can check it on board with a multymeter. It stops working. I unsoldered it, opened it up, cleaned it and resoldered it. It now accepts CDs and DVDs and does not spit them out after a while. If only I could find a solution for the buzzing sound. It must be defective design. Maybe change C560 and C561 on main amp PCB with smaller capacity ones? Or maybe put away the toroidal transformer?
This is the LAST item I'll ever buy from Phillips. Period. They put an unfinished project on sale... Shame on them..
Greetings from Greece
George
Sep 09, 2007 | Philips DVD Micro Theater Shelf System...
Can i play my mp3 HDD through the Unit speakers
if it has red/white RCA style inputs on the back you can just buy a cord that will plug into the headphone of your MP3 and into the RCA jacks on the stereo.
Sep 07, 2007 | Philips DVD Micro Theater Shelf System...
Mcd288 problem
Try not to use any rental dvd discs or dvd burner discs. Go get a brand new dvd movie(again,do not burn a DVD disc and play in this unit.) and put it in see if it works? Should have at least 2-3 movies for testing.
If you have tried to put in some BRAND NEW DVD movies and still doesn't work,you have a problem with the unit.
Jul 23, 2007 | Philips DVD Micro Theater Shelf System...
Philips DVD Micro Theater Shelf System (MCD288) System Logo
517 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
