Question about Gigabyte GA-8I945GMF Motherboard
Ps/2 port i got problem with my ps/2 port. the port not working
If your board is still under warranty then ask for replacement.
there are available converter in the market. look for usb-ps/2 converter.
Posted on Feb 26, 2008
Mouse can not work
this is usually do to a port going out or the total failure of the mouse.. or if it's a rather old mouse, the ball underneath is too worn to work.
if it's the port, there are 2 kinds, one is a round port (PS/2), you will have to turn off the computer to remove the mouse from this type of port.
if it id the round ps/2 port, you will have to either get a new mouse using usb, or you can try a new ps/2 based mouse.
REMEMBER you cannot plug in or remove a ps/2 mouse while the computer is still on!
The next port, and most common is the usb port. it's a small rectangle.
You most likely have atleast 4 of these on the back of your computer, and most of the newer computers have 2 on the front, sometimes in a hidden panel.
Sometimes if you are a windows user, windows will set a usb port aside for what normally resides there, and a mouse in a port that usally houses a printer usb plug will make windows not see the mouse sometimes.
Removing a usb port mouse is rather easy, you dont need to turn the computer off to do so.
Before considering replacing a usb mouse, try putting it into another usb port. sometimes this will work. also, see if the lights are working underneath when plugged in. (optic mouse, not ball mouse).
if you have determined that your mouse is broken, then the next step is to replace it. bestbuy sells mice for about 25-30 dollars.
if you dont mind waiting 3-7 business days, a reputable online retailer like 3btech.net can sell you a mouse for about 15-20 dollars, and 3btech does not charge for shipping.
usb mice can be found here:
http://3btech.net/keyboardsmice1-us.html
ps/2 mice can be found here:
http://3btech.net/keyboardsmice1-ps.html
Jun 17, 2010 | Computers & Internet
Does the labtec wireless mouse turn itself off when not in use
You should always safely shut down and turn off your computer before plugging or unplugging the mouse from the PS/2 mouse port. If you do not safely turn off your computer, you may damage the mouse port, the mouse, or both.
Your Labtec mouse should detect and function by simply connecting it to the computer´s PS/2 mouse port or USB port. If you have 3 Button Labtec Mouse (M/N: M-CAC64), your mouse will work in the PS/2 and serial port with the supplied adaptor. If you are using the 3 Button Labtec mouse, we recommend using the PS/2 port. To determine the model number of your device, turn it upside down and look at the label. Model numbers are indicated by "M/N:". This will help you determine what system ports your Labtec mouse can be connected to.
Thank you
Mar 14, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
I just buy a4 tecch keyboard (X-slim multimedia) and PORT USB doesn't work... Pleace help me
Hai,
If your keyboard has PS/2 port you have to purchase PS/2 to USB converter and then attache it to your keyboard. Then in your BIOS you have to confirm whether USB keyboard is available and it is enabled or not. If not you have to enable then your USB keyboard works.
Regards
Dec 28, 2009 | A4tech A4 KL-23MU X-Slim multimedia PS/2...
PS/2 mouse port not working?
Hello fredbeer,
Besides the obvious checking with your device manager, you can download a port test kit HERE. That will be able to test if it's working. The other thing you can do is switch the keyboard into the mouse port and the mouse into the keyboard port. You should get some errors, if not, one of them will work and the other won't. Hopefully, you'll get the keyboard in the mouse port to work, so you know the port is working. Also, if you have any other PS2 devices that you can test it with.
Good Luck and don't forget to leave a rating based on my solution.
Thanks
Mark
Apr 15, 2009 | ASUS A7N8X-X Motherboard
My Trackman Marble FX stopped working after dealing with a virus. Never could get it to work, maybe I just wore it out. Bought a Logitech optical mouse but the left click is messed up. It locks and does a...
It could be a bad Trackman or a bad PS/2 Port.
1st test if it's the port by trying another mouse, or by trying this Trackman in another known working PS/2 port on another computer.  (don't forget to reboot each time you plug in a PS/2 device)
2nd, you can try using a PS/2 to USB adaptor.
These two have great reviews...
$12 TRIPP LITE USB to PS/2 Adapter Model B015-000
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812120006
$20 SIIG JU-ACB012-S2 USB to PS/2 adapter cable
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812191021
Best of luck getting that wonderful Trackball working again!
~Andrew
EmpoweringSolutions
Feb 20, 2009 | Logitech Trackman Marble FX Trackball
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
Keyboard not working
Minimal information to go on. Since you didn't specify whether this is a laptop or desktop, I'll respond with the assumption that it's a desktop.
Power off computer.
Install new (known working) keyboard.
If that doesn't correct the problem, your issue is probably with the PS/2 or USB port your keyboard is plugged into.
If you are using a USB keyboard, first try moving it to a different USB port, then booting. If that doesn't help, try a PS/2 keyboard.
If you cannot get a known good (working/new) PS/2 keyboard to work in replacing a PS/2 keyboard, try a USB keyboard.
Jul 22, 2008 | Computers & Internet
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Mar 02, 2008 | Sakar 62150 Keyboard
Gigabyte GA-8I945GMF Motherboard Logo
65 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
