Question about Creda IWD12 Front Load Washer / Dryer
Dial keeps turning and clicking
Hello. My Creda IWD12 has this problem, where it gets halfway through the cycle then the dial just slowly turns and clicks. You have to do a combination of turning it off and on again, putting it on 'pump out', and putting back on to where it left off (usually rinse/spin). Anyone else had this?Thanks in advance! Sue
  • 1 more comment
  • suekeogh Feb 26, 2008
    Thanks Bob, that's really good of you to reply! I'll have a look, might get someone out to look at it, have been looking into the cost of new washing machines and they're not cheap! Sue
  • ebonyp29 Aug 12, 2008
    my creda IWD12 does the same thing gets half way through cycle then stops and dial just goes round on its own and water does not pump out. have checked filter and pump and cleaned them but still no luck can anyone help thanks
  • addyboo Apr 04, 2009
    I have this same problem and the instruction manual is no help! not sure how to empty the filter I assumed it was bottom right of the machine but it doesnt seem to look like a filter when ou take it out.
Try emptying the water and debris from the filter, seemed to work for us.
Posted on Sep 12, 2008
    Problem Solver:
  • 8 Answers
Sue worth having inlet valve checked also have heater checked at same time ! is the machine draining ok !! if not there could be blockage in drain system or faulty pump good luck- regards bob btw
Posted on Feb 26, 2008
The fast spin cycle on my creda 1000 will only spin slowly,leaving clothes wet,any thoughts
This machine has a variable spin-speed setting. You can set the spin-speed RPM (between OFF and 1200RPM) using the smaller dial located next to the main wash programme selector dial.
I hope I'm not stating the obvious, but appliance "faults" are often simple and don't require taking the machine apart or calling a service engineer. If you've already tried the above suggestion and your washing machine is still spinning slowly, please post back and I will try to assist you further.
Regards,
BElectric
Nov 27, 2010 | Creda W100FW Front Load Washer
Spendide 2100 won't do dry only cycle?
I own a Splendide 2100; it is installed on my sailboat. I love it, but it is a little picky. To do a "dry only", set the time you want and then ensure the dial is on "Reset" (doesn't matter which one). The LED should flash very slowly indicating it is ready to run a cycle. Turn the dial to the "Dry" indicator of the dry cycle you want. You will hear a very short gush of water (not sure why it does this) and the dryer will start. If you want to stop it before the time runs out, turn the dial to "Reset", power it off for at least a minute, then turn it back on. You should hear the lock click letting you know you can open it. Don't force the handle or you can break it.
Apr 10, 2010 | Splendide 2100XC
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
Creda 1200 Excel- The machine is not washing clothes properly and they come out as they went in. Nor does the dial move round on its own, i have to physically move it. At the end, there is still fabric...
this will help you with the fabric conditioner on Creda 1200
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 08, 2009 | Washing Machines
I have had my Creda 1000 Supaspeed- Economy Plus for about ten years. Just one week ago the program panel stopped advancing at the end of first rinse with all the water still in it. I turned it off and...
Crea8tivefeng,
I wish I could be of some help but the same thing just happened to me! I have also had this washing combo for almost ten years. I haven't yet tried looking at it as it just broke. I can be handy but I have never looked at a washing machine before. With out looking at it I wonder if it could be a belt not letting the spin cycle work. Maybe the dial is broken? If you have found a solution to the problem I would love to hear back from you.
Derek
Oct 07, 2009 | Creda W100FW Front Load Washer
Creda dryer belt
release tentsion from belt pulley
Feb 01, 2009 | Creda IWD12 Front Load Washer / Dryer
My creda iwd12 front load is not working
If the m/c completed the wash cycle, it may be that the clothes have not rinsed, or incorrect prog selected, or incorrect temp selected,
Check to see if the drum actually goes round with clothes in, as a worn or broken belt will obviously stop the clothes from being washed.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda IWD12 filter.
As far as I remember it goes like this.
take the filter in your hand and turn the knob counter clock wise intill it almost comes off. Then gently shuff it into the filter hole. Push it in as far as you can and than tighten it again.
Maybe the following link will help you
CREDA IWD12
Apr 20, 2008 | Creda IWD12 Front Load Washer / Dryer
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
Creda IWD12 Front Load Washer / Dryer Logo
514 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
