Question about Panasonic PT-47WXC43 47" Rear Projection Television
Convergence chips 110 installed but unsuccessful
I installed the convergence chips 110 on my Panasonic PT-47WXC43G but still I have sound but no picture. The power light does not flash, just stays on. I did not check the resistors! Did I burn the new chips 110 and have to reinstall new ones and would this also cause the TV to not send any juice at all to the small tubes and also the big ones?
  • Bear43 Feb 27, 2008
    For my Panasonic PT-47WXC43G
    Which are the resistors to check that pertain to the ic's..do you have a picture of the board showing the chips. Also how do I know if it's a bad resistor..I know I will need a meter
    Thanks for your help
    Bear43
    President:
  • 4,402 Answers
Check the resisters or send the board in to ptscorp.com
if you find bad resisters chances are you blew the ic too
Posted on Feb 26, 2008
  • Cary Farah
    Cary Farah Feb 27, 2008
    they are 1w resisters in other words they are the larger size resisters by the ic's, sorry i dont have a pic
Convergence problem Panasonic PT-53TW53G
First I know this set well, did you pull out the board or the light box to replace the chips?
Convergence problems are usually easy to see...
see attached photos and tell me as much as possible.
SD TECH
Nov 10, 2011 | Panasonic PT-53TW53 53" Rear Projection...
I have a pt-47wxc43g panasonic projection tv and when i turn it on the red light blinks three times and it does not turn on.
Three times red light blinking indicates problem of convergence output chips are bad, tv has 2 chips that need to be replaced.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you technical info OR local tv repairman will do this job for you.
Thanks.
Dec 27, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WXC43G
no the ICs wear out the PS3 could contribute a little. But you will need to replace both STK392-110 Convergence ICs. You can get them at this link with free instalation instructions with pictures so you can do the repair yourself. Here is the link
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Pt 53wx53 convergence
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Dec 16, 2007 | Panasonic PT-53WX53 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
97 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
