Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Anonymous
Level 3:
President:
  • Master 949 Answers
  • Posted on Feb 15, 2010
Anonymous
Master
Level 3:
President:
Answers
949
Questions
0
Helped
421116
Points
3655
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
2helpful
My vacum roller brush dosenot work
The most common failure there is the drive belt from the motor to the brushes has failed. Consult your local vacuum store for a replacement. Normally they are fairly easy to change. Check and see if the brush is free wheeling or needs a push to get it to turn. If the belt is broken or worn out the brushes will turn freely.
Broken need number for new belt
most of the kenmore upright cleaners use the panasonic upright belt so you may fined them at your vac shop or local hardware store,home depot
Belt is broken
there is no belt on your model there is a reset button on the side by the brush
1helpful
Lever & belt placement in Kenmore Progressive upright vacuum
You are correct. The belt is supposed to go around the peg that is connected to the lever so that when it is on the Floor /Tools setting the belt is not driven by the drive shaft.
9helpful
3answers
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
1helpful
Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Motor comes on-brush not turning
Most power heads use a belt to turn the brush roller. Open it up and u'll probably find the broken belt laying in there
1helpful
Sweeping part of the vacuum stopped spinning.
Is the belt stretched or broken? There needs to be a (not-stretched and not broken) belt connecting the rotating brush (agitator) to the motor pulley on the vacuum.
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
