Question about Epson LQ-1050 Matrix Printer
Cross printing i am getting print in focus dos mode printer ok , but while taking tally document it was gouing cross like from left to right, what was the problem on printer Epson LQ-1050+ matrix printer, how to rectify this problem
Its look like a alignement problem of head pls. check it from your printer engineer
Posted on May 13, 2008
    Novelist:
    Champion:
  • 254 Answers
I'm not sure exactly what your issue is, but Epson printers should be well supported as far as drivers are concerned. Do you have the correct driver loaded? If you are trying to use a Tally driver with the Epson printer, this may not work right.
Also, when printing from Windows, some older printers print only in a single direction, from left to right, instead of bi-directional (left to right & right to left).
I've used a few different Epson dot matrix printers, and problems have been few.
Posted on Feb 28, 2008
Landscape printing on t2340
printers>properties>general tab>printing preferences change print mode to landscape from portrait..........
Jan 23, 2013 | Tally T2340/24 Matrix Printer
I am not able to take the print from tally
to print anything from telly
go to the page you want to print then hit alt+p
on right side hit the button select printer
set your printer in it
hit enter and accept
now you can print from tally.
Mar 05, 2011 | TallyGenicom 2265+ Matrix Printer
Can not print in duplex mode I can not print
Why don't you just print the data on the one side of the page and then simply turn the page over and reinsert it into the paper feeder and then print the next bit of data, therfore you end up with both sides of the page printed without worrying about printer commands that seem to fail.
Feb 12, 2011 | HP cp1700 Color Inkjet Printer
"how to print settings for
If you are talking about one of the TallyCom print servers there is a small blue test button on the side of the box, press this when the print server is connected to a printer that is online. If you press the test button for over 9 seconds the print server will be reset to factory settings. If you want to print from DOS to a network printer as I recall you have two options; 1) Install the printer in Windows and share it, you can then print to the share name 2) Use "NET USE" command in DOS to map a local port to a network port, this is nessesaey if you can not print to LPT1 or COM1 from the application. For help of NET USE go to DOS and use the help options.
Jan 05, 2011 | Tally (43555) Print Server
Sir the bottom half part of 2nd page left blank and the data is printed on 3rd page.
HI, The usual issue with this problem is the settings on the document. Try adjusting the margin on the document then try to print again.
Cheers!!
Sep 01, 2010 | Tally 6306 Matrix Printer
We are not getting print out from network printer from Tally but we are getting print out from other software like excel & word
It's simple. because you didn't select the print through DOS mode during printers installation. So now unload your printers driver and re-install it selecting print through DOS mode also.
Mar 10, 2010 | Computers & Internet
Tally Genicom Slow Printing in Foxpro Dos Program
change the connecting cable serial or parallel what you have it may help you.
Jun 15, 2009 | TallyGenicom 2280 Matrix Printer
I am not print from tally software it is getting failed
please check that u select the proper printer before preceeding for print command. Also check that the printer connected to ur system is ur default printer.
Jan 10, 2009 | HP LaserJet M1522nf Multifunction Printer...
Cannot print from DOS mode of shared printer
Make sure that your computed is on the same workgroup or domain as the other computers are.
You can check that by going into the control panel. Press system. Press the computer name tab. Change the domain name or workgroup accordingly.
Oct 31, 2008 | TallyGenicom 6312 Matrix Printer
HP PSC 1315 Printer frozen in "deleting" mode
It seems a Problem with the Print spooler.
You can try a print spooler refresh>
Go To Start> Run> And type services.msc> Ok
In the services window locate for print spooler> And bouble click on the same> It will open the print spooler property window>
Now Bellow service status you should see the Stop Tab highlighted> Click on the same (you will see a small winow popped up and it will close)
Now you will see Start Tab Highlighted> Click on start ( And you will again see a small winow popped up and it will close)
Now stop should be highlighted.
You can try this steps a couple of times untill you see STOP highlighted.
Then click on Apply or Ok and close all the windows and try if it does any better..
IF NOT YOU CAN TRY THIS.
Go to printer and faxes and right click on the printer icon and left click on properties> Go to Advanced> And here you will see ckeck mark on: Spool print documents so program finishes printing later.
Now Select: Print Directly to te printer that will uncheck Spool print documents so program finishes printing later.
Now click on apply and ok and try printing.
If it is better than keep the same settings.
If not you may have to do a complete Print spooler cleanup.
Good Luck
Sep 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
