Question about Compex MicroHub TP1008C Networking Hub
Connecting campus wide networking to hub
In my college recently we networked the whole campus using utp cable.The problem now i m facing is.we have a general hub at each department block.I have a lan cord from that hub to my pc.It works fine with server's IP setting.When i tried to connect it to a another(Tp1008c) hub and connect three more pcs to it with .I m not getting any network link.Especially i need it to access net.All my pc which i need to connect are running vista...
  • prithivxx May 10, 2008
    the same here
  • shalamit May 23, 2008
    i am unable to connect my laptop (using Vista) with my desktop computer (using XP) through broadband network. I need to use printer with my laptop.
It is due to connectivity problem pls check the connection
Posted on Mar 05, 2008
use cross cable to interlink between hubs (ex. from hub1 to hub2 & from hub2 to hub3 .... and so on...)
use straight cable to interlink pc to hub
thank you,
Allan
Posted on Feb 27, 2008
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
RF2800
You must see on you UTP cables connectors, are there right?
May 28, 2011 | NorStar (RF2800A) Networking Hub
I want to connect the netsurfer laptop using the internet wireless of ukzn (howard college) campus but it doesn't go through what coulf be the problem
It could be that the college WLAN (Wireless network) has some proxy settings. If you are from the same college you can try going to the IT support of your campus so they can configure your computer to be able to connect to the network.
May 19, 2011 | Computers & Internet
Hi when i connect my ir 3300 with computer the ir3300 is showing network problem. even i had change two no. of cross cables.
Wich kind of problems, you are unable to ping the copier or you cant print, or ...
If you connecting the PC directly use the croswired cable if you are connected over HUB, or other network device you must use normal UTP patch cable, from copier to the HUB, and from the HUB to PC.
Do you have right IP, subnet and gateway?
Check the network cards on copier and PC, if you crimp the cables by yourself check the cables,...
Do you have printer FLASH on your copier?
When did errors occured? Were you able to print before?
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Is 30meters UTP cable are able to connect to hub or switch?? Thanks!! Adam
Yes you have up to 100m. More info and standards http://en.wikipedia.org/wiki/TIA/EIA-568-B
Jul 30, 2009 | D-Link DFE 916 (DFE-916) Networking Hub
HP Procurve 1700-8 working upto 10m UTP cable only.
It is not a distance limitation of the switch, rather the cabling in the walls and ceiling. If the cable is Cat5 it can be up to 100M, but this can be drastically reduced with things like EM interference from fluorescent lights, kinks in cable and more. The switch auto detects the maximum reliable speed and this interference would cause it to drop to 10MBps. If you don't have a cable certifier (very expensive) you may want to consider simply replacing the cabling run with Cat6 following best installation practices. You can learn more at http://www.lanshack.com/cat5e-tutorial.aspx.
Feb 14, 2009 | HP ProCurve 1700-8
Difrence of lan wan
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Jul 10, 2008 | Computers & Internet
Network
Also you would to configure the TCPIP address and network name for each PC so they can share data etc.
May 09, 2008 | Computers & Internet
I need to connect to two computers. How do I connect? One computer connecyed John
you connect the two computers in many different ways, 1. you can use a router 2. you can use a port switch or network hub 3. you can connect this two computers thru a UTP CABLE with a cross over connection. after connecting using either any of the mentioned above you need to run the network wizard inorder to have a network.
Apr 19, 2008 | Computers & Internet
Connection Problem
maybe its not in the hub/router, or in your lancard has the problem. try to change the networking cable you are using it sometimes the cable has a teared wire inside, or probably the lancard or your hub does not work for the type of networking cable, there are 2 types of connection for UTP cable first is the Straight through cable and the second is the Cross Over connection. Try to mix and match the cable that you have and try to use another one instead..
Nov 19, 2007 | Cnet CNSH-1600
Compex MicroHub TP1008C Networking Hub Logo
339 people viewed this question
Top Compex Computers & Internet Experts
Michael Galve
Michael Galve
David Payne
David Payne
Rose li
Rose li
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
