Question about JVC KD-AVX33 Car Video Player
HDD with videofiles not working
Hi I have a lacy 160G (no extra power needed) plugged into the USB. The lacy is in FAT32 format in order for the JVC to read the files. I have audio and video files on them. Somehow it only reads and plays the audio (mp3) files and not the videofiles. Anyone with a solution?
  • Anonymous Mar 30, 2014
    USB can play what video files
  • Anonymous Apr 01, 2014
    USB set for audio used, FAT32 , and track 16, 24,64 kbsector
  • 10 Answers
I had the same problem on memory stick. If I have pictures only on memory stick it is working (pictures played in a slide show). After that I've try with a mixed CD (MP3 + pictures) and was the same problem - only MP3 played. I think KD AVX33 doesn't know to read both type of files at the same time.
Posted on May 05, 2008
  • Ion13 May 05, 2008
    Sorry I didn't finished :) To play pictures or videos from same source you have to change the "File type": go to "AV Menu" > "Setup" > "Disk 1" > "File Type" > "Still picture" / "Video", but now you can't play MP3 :), so repeat the procedure above for each type of file... :)
Windows 7 do not recognise the Lacie 1T lc3u device
Hi Dan
Does this work on other windows systems such as XP?
This could be anything from a defective HDD, defective Lacie enclosure, Odd format on the Hard disk, bad or confused USB port on your PC etc.
Check it is seen in device manager
Check it is seen in disk management
Check it is formatted in either NTFS or FAT32 in disk management
This are the best suggestions i can think of with such little information.
Tape Drive Repair UK Based We repair all makes models and formats
Jan 18, 2014 | Computers & Internet
How do I get it to work on my Ps3
Hi Damian, if you can't read any file from it it's because it's probably format as NTFS. You have to format it as FAT32 otherwise PS3 won't read anything from it.
Also, you have to create two partitions on it because PS3 won't read anything bigger than 512 GB. When you got it to fat32 go to MOVIE, PHOTO or MUSIC and hit the triangle button in order to display your files.
Regards, Peter
Aug 09, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Hello i plug my lacie 1tb external hard drive into my ps3 and it does not get regconise but when i plug it into my pc it works perfectly
ps3 is designed to take certain drive formats. I'm no sure which ones but you could test. Just back up all the files and reformat it with FAT32, FAT...and if it doesn't work just restore the files because gaming consoles were never designed to take externals used by computers.
Dec 01, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
JVC KD-AVX 40 compatiable USB H/Drive
You can use any non powered USB drive (gains its power from usb only). You just have to plug it into your PC and select Properties > Format then make sure you format it in FAT12, 16 or most commonly (recommended) FAT32 file system.
Once you've done this you can transfer all your music onto it then plug it into the USB port lead from the back of the head unit
Feb 26, 2009 | JVC KDAVX44 Car DVD Player
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
How to i reformat a lacie 500gig external hdd
The Mac OS can't natively write to NTFS (it can write to FAT32 however). But if you install MacFuse followed by NTFS 3-G on OS X then you'll be able to write to your NTFS drive.
Oct 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
USB Hard Drive
You cannot run a External Hard Disks (...that's what the User Manual say) It only reads Flash Drives, I have tried 8GB.
Oct 01, 2008 | JVC KW-AVX800 CD Player
HDD 500 gig will not work USB
its probably not in FAT32 format
Jan 17, 2008 | Philips DVP5982
Unable to connect USB hard drive to KD-AVX33
I bought this model also. It depends how much power the external drive uses. The models with 2 usb cables usually don't work because they require more power.
The hdd cannot be bigger than around 20GB, not more then 12 folders and no more then 2500 files. I saw at some forums.
If you have a pen drive at 8 to 12 GB i don't think you have problems with these. anything bigger and you have to be lucky.
Maybe at my company i can try some drives as we have them to test/use.
Nov 05, 2007 | JVC KD-AVX33 Car Video Player
JVC KD-AVX33 Car Video Player Logo
153 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
