Question about Canon IXUS V2 Digital Camera
Canon ixus SD card problem
My cannon ixus keeps telling me "card locked"when it's not, i've formatted the card and even purchased a new sd card but it's still saying the same!help!
  • 6,831 Answers
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Canon IXUS 970 IS will not recognise 2GB SD card although it used to do so
The memory card might have been damaged.If it was a problem with your camera it might not have recognized your 32k sd card.
So buy a new sd card.
Jun 10, 2012 | Canon IXUS 970 IS Digital Camera
Card locked on cannon ixus 8105 digital camera
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 03, 2012 | Canon Cameras
I bought a new memory card for my Canon Power Shot SD 400 Digital Elph, but it has an error message that comes up. When I scrolled through the Menu to format the card, the format selection is grey and...
Your older camera can only work with 2GB or smaller standard SD cards. It is not capable of recognizing the newer format 4GB or higher SDHC cards. Fortunately, old format 2GB SD cards are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them.
Sep 02, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
MEMORY CARD OF cannon digital IXUS 80 I5 GOT LOCK.HOW TO UNLOCK IT.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 15, 2011 | Canon IXUS 80 IS Digital Camera
I have a canon ixus 700. i've tried to insert a new SanDisk 4 GB memory card. the menu says the card is locked when (i've treble-checked) it definitely is not locked. i read from others that...
According to the specs on Canon's web site, the IXUS 700 works with SD cards, not SDHC cards. SD cards are limited to 2GB in size (there are rare 4GB SD cards, but they tend not to work in SD devices).
Of course, it's your call as to how definitive any manufacturer's web site touting their product might be.
Jul 20, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Sd card
There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
I hope that helps.
Mar 20, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Cannon IXUS 40.Saying, Card Locked.How do you unlock it?
In case it uses the SD card, then there is a lock feature in the card. You will need to unlock the card so that it becomes read/write enabled. In lock position, it is read only, so you can read the files from it but cannot create any more files.
Most SD cards have a switch on the edge of one side of the card. Sliding it up or down will unlock or lock the card. When the card is locked, you will not be able to transfer any audio tracks. Nor will you be able to play any copy protected files. We recommend you always keep the card unlocked.
sd%20card%20lock%20slider.jpgNOTE: We have found that on some cards, if the slider is even halfway towards the lock position, the card will be locked. Make sure that the slider is all the way to the UN-locked position.
Nov 24, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Transform Duo Stick into an SD card ~ Possible?
Hi Qwin,
Although you cannot directly use your Duo Stick in a camera which supports SD, you are able to purchase a memory card reader to support both formats. This means that you can transfer data from the Duo Stick or the SD onto your computer, and then put the data onto the other card.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 09, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon IXUS V2 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
