Question about Kenmore 43052 Front Load Washer
How to Remove the bearing outer race from the shell of the washing machine tub
I removed the inner race and bearing
  • Ron Coons
    Ron Coons May 11, 2010
    not sure of the question
  • 156 Answers
Bearing on most can not be removed there molded in the outer tub comes with the rear half of the tub already installed
Posted on Feb 27, 2008
Water leaking from bearing at back of drum
you better get at this soon,the lip-seal is gone from the outer tub and now water has penetrated the bearings behind this lip-seal,the longer you wait the harder it will be to remove these bearings and if its a plastic outer tub you can destroy this tub when removing the old bearings,the inner tub needs to be removed,the rear access needs to be open the motor pulley removed,the c-clip that secures the outer bearing needs removing then the inner tub can come out the front to access these bearings for replacement
Mar 24, 2011 | Indesit W 123 Front Load Washer
How to replace bearings in hotpoint washing machine. Has anuone got a plan view of what I need to do.
Hello,It's fairly straight forward,not easy though.The facial comes off(take the dispenser out and remove the four screws), front of the machine comes off (3 screws at the bottom and 3 behind the facial,the outer tub front comes off.)The pulley on the rear comes off,the inner drum can be knocked through.This gives you access to the bearings and bearing seal,not the easiest to get out.A lot of the time the outer race is left behind from the front bearing and it's a nightmare to get out.Hotpoint use a special bearing tool,get yourself a spider and bearing kit as well as a new tub seal.
Thanks
May 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Has a squeek when it is in the spin cycle
mostly the motor problem  and other possible problem can be  that a bearing is bad.If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 08, 2009 | Washing Machines
Noisy when spinning
The noise coming from this machine as it spins is due to -- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Picture1 - Picture2
May 07, 2009 | GE WJSR2070B Top Load Washer
Maytag washer MAV551EEWW top load with loose tub
Picture1 - Picture2
May 07, 2009 | Washing Machines
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
Picture1 - Picture2
May 05, 2009 | Frigidaire Washing Machines
Made a loud noise and drum stopped moving
Picture1 - Picture2
May 03, 2009 | Hotpoint WMA40 Front Load Washer
Grime on clothes from washer
Picture1 - Picture2
Mar 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes
check out for this link
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front load washer FWT449GFS1 grinding sound
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 43052 Front Load Washer Logo
278 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
