Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Please Help! I just moved in this house and i immediately plugged my tv, as soon as i plugged it, it popped. It does not respond. I tried plugging it in other sockets but it does nothing, i later found out that the socket i plugged it into was a 220 outlet. Is it a fuse or a bulb, did i fry the mother boards? How do i fix it, where do i start? Please help me, i love my tv i do not want to spend money on a new one, thanx!
  • 979 Answers
You will probably expend about 150 to 200 dollars in parts for this set, as the input devices were rather overwhelmed with that higher than normal voltage. As is the case with Murphy's law, the fuse might still actually be Okay..accordianman
Posted on Feb 26, 2008
Keeps popping DMI immediately when it is plugged in its a refridgerator
Refrigerators need to be plugged into a regular outlet without anything else plugged in. DMI's, GFI's, or GFCI's are designed to trip at the slightest increase in amp draw. When the compressor turns on the outlet senses the spike and trips the curcuit. So to fix the fridge plug it into another outlet that is not part of the dmi circuit.
Nov 02, 2016 | Frigidaire Kitchen Ranges
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
With the unit unplugged remove the machine compartment and visually inspect for and burnt marks or frayed wiring. if non is seen, remove the wiring connectors from one component at a time and re test by plugging the unit back in. This will help you isolate the issue hopefully.
The machine compartment is on the back and the power cord is attached behind it. It is usually connected with 1/4" screws so a socket or nut driver will help you gain access.
Apr 22, 2014 | Refrigerators
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
BRAND NEW JUST TOOK OUT OF BOX VIZIO E320VL 32 INCH FLAT SCREEN TV Menu constantly pops up and flips endlessly through the choices. Ignores you when you try to enter a selection and move back to what...
I would not keep a new LCD TV that has immediate problems. I would get a refund and purchase a more standard brand television. Experience has taught me that if one has problems immediately with an LCD TV itself, it is likely to continue to be problematic.
Thank you for using FixYa.
Dec 26, 2010 | Vizio VW32L 32 in. LCD HDTV
We have arc fault breakers on our house built in 2002. in trying to plug in our 40'' lcd tv the breaker kicks out as soon as the plug touches the outlet. We've even tried brand new high end TrippLite surge...
Well, considering all TV's these days have what is called a SMPS which means Switch Mode Power Supply. As soon as your plug enters the outlet it will ark, because the power supply starts up immediately, so my suggestion would be is to kill the breaker to that room then plug the set in and then reset the breaker. Let me know how it turns out.
Oct 13, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Old GE 13 inch TV TX826TB 13GP243 does not respond consistently when I try to turn the power on. My neighbors just moved and had no spot for it in the car. They watched it all day the day they moved. I...
Doesn't Tried another outlet and it turned on suggest the problem is with the outlet?
Are you talking about a power or a TV signal outlet, please?
Nov 29, 2017 | GE 13GP243 TV
Popping the Breaker
Ok, first a couple of things, you didnt mention if it popped the breaker when you were using the oven, burners, of both or if it does it as soon as you plug it in. If it does it as soon as you plug it in, you have a short in the back of the unit. you need to pull the back panel off and look to see if the broil or the back element wires were touching the the back panel. This is a common short. If it only does it when you are using both the burners and the oven, you might have a weak circuit breaker that needs to be replaced in your house. Unfortunately, age has little to do with it, I've gotten new breakers that didn't function correctly.
May 24, 2007 | Frigidaire FEF326 Electric Kitchen Range
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
