Question about Tascam US-144 Sound Card
Tascam midi and audio conflict error
Hi i bought a tascam us-144 and use it with logic 5.5 on my toshiba satellite A105-s4334 duo core, 2 gig ram. whenever i try recording midi or audio, and even playback, sometimes it crashes or i keep getting a midi/audio conflict error message. but when i just use the mini jack mic input on the laptop and dont use the tascam at all, everything is fine. wtf?
anyone able to help??!?
im beginning to think tascam sux s#$@....
plz help if you can!!! =(
  • milo1sugar Feb 28, 2008
    hey thanks heaps m8!!
    i'll give it a go and see what happens =)
    cheers!
  • 30 Answers
First try turning off the onboard audio device using the BIOS interface. Try pressing f4, f2 or delete key rapidly at the flash screen beginning when you first turn on the computer. Look around in the bios (usually in "integrated periperals" area) and disable any onboard audio options that you see.
-In windows XP you can go to Control panel - Sound Devices and change the "map through" feature, select your default device, and run a hardware test simulation with a microphone for each device. Nice setup btw.
Posted on Feb 27, 2008
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
My toshiba A105-S4334 laptop is running windows xp it is compatible w/vista. Is there a noticible benefit in upgrading to windows 7. Toshiba says to be able to upgrade this model the second digit of the...
I have both Operating ssytems. If your happy with XP stay with it. Vista has big changes and so does Windows 7. Your computer has to have a duo core processor which I think yours does not have. If it does it will state that on the bottom label. If not XP is your only choise of programming
Jan 21, 2011 | Toshiba Satellite A105 Notebook
Where is the memory located in a Toshiba Satellite A105-S4334 laptop?
Hi
The memory is normally located underneath the laptop
normally a oblong cover with 2 screws
just undo the screws and remove the plastic plate
Jan 19, 2011 | Toshiba Satellite A105-S4334 Notebook
I have a Intel® Core? 2 Duo Processor T5200 in my Toshiba satellite a105 s4334 notebook. what can I upgrade to? the chipset is a 945GM from intel and the fsb is 533, L2 cache of 2MB. please help I...
Go to this page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1484712&rpn=PSAA8U&modelFilter=A105-S4334&selCategory=3&selFamily=1073768663
From there click on gthe detailed specs and it will show you the upgrades you can do.
Aug 06, 2009 | Toshiba Satellite A105-S4334 Notebook
Tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Feb 01, 2009 | Tascam US-144 Sound Card
Crashing every minute
I have found that the tascam 144 freezes the system evan when using other software than Live. It looks up with Cubase and other stuff evan Windows media player running sound thru the tascam. The problem is erratic and acts like an IRQ conflict and I still believe Tascam has fallen real sort of the mark by abandoning the customers. They are without a dought responsible for this problem and should step up and FIX it NOW. We are many having problems it is no fluke and I for one am discusseded with the total lack of support for what they have released as a viable and workable unit. LIES just to sell their stuff. I feel that Tascam's support should be in on this forum and start to work out the diffinative answere.
Anyone want to buy a cheap Tascam US 144 that won't do what you want. I achive move by plugging into the MIC or Line in on my system sound card than I get from the great Tascam device I bought in good faith and can't use.
THANKS FOR NOTHING TASCAM.
May 20, 2008 | Tascam US-144 Sound Card
Hellp!
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Not responding
you might want to downgrade to xp because vista uses alot of ram to run it. you could also get more ram. you need about 1gb and a half to 2 gigs to run most recording softwares and interfaces. i personally use vista cause i lost my xp disk and i got 2 gbs of ram and everything runs great, but if you really want to get into recording do what im doing and save up and buy a mac.
sincerely
andy kastrinelis
owner of addex recording inc.
Oct 13, 2007 | Tascam US-144 Sound Card
Tascam US-144 Sound Card Logo
178 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
