Dryers Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer does not get hot, already changed the heating eliment
Anonymous
Level 2:
Director Badge:
Uploaded 100 video answers.
  • Expert 213 Answers
  • Posted on May 10, 2010
Anonymous
Expert
Level 2:
Director Badge:
Answers
213
Questions
0
Helped
150261
Points
436
This might help
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Anonymous
Level 2:
Sergeant:
  • Expert 215 Answers
  • Posted on Feb 15, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
215
Questions
Helped
43110
Points
517
There is what is called a TOC fitted onto machine, you will find that this has activated and cut power to your heater eliment. The toc is fitted near to your heater, it is about 1 inch square, and will have 2 wires going to it. 1 wire will then go to your heater.you will need to replace this but just check it first Also some machines like White Knight do have a small reset button on rear of dryer. this is normally a small red button, and you just push it in..
2 Related Answers
Anonymous
  • 1244 Answers
  • Posted on Jan 13, 2010
SOURCE: haw do you test to see if heating eliment is good
use a OHM meter across the terminals to check for continuity but my money is on you have a bad/defective limit switch and they are on the heating element housing itself chek them for burnt! weak contacts or broken wires impedeance and lose terminals change them if any signs of loseness
Anonymous
  • 43501 Answers
  • Posted on Jul 01, 2011
SOURCE: will not get hot. just blows cold air. was
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Hotpoint dryer wont heat
bad heating eliment
Nov 16, 2013 • Dryers
Works no heat how to fix
Change the heating eliment
Feb 29, 2012 • Dryers
Will not get hot. just blows cold air. was wondering how many heating eliments are in the dryer?
heatman101
Haw do you test to see if heating eliment is good dryer not hot
Jan 13, 2010 • Dryers
Maytag ldg8406AAE gas dryer will not get hot
Could be the eliment..
A way to check it -
Remove the exaust hose.
Put a mirror near the exaust hole to see inside an see the eliment.
When on - it should be glowing hot..
Also could be a clogged exaust path..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 01, 2009 • Dryers
1helpful
Electric dryer model LER6611PQ0 will not heat up - only 4 years old
Could be a fuse..
Could be a heating eliment..
A way to check the eliment is -- remove the exuast hose.. Put a mirror to see inside the hole.. Whenrunning the eliment should glow hot..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 • Dryers
1helpful
Free standing kenmore dryer series 90 floor model not stacked not drying
Could be the heating eliment..
A way to check it ---
remove the exaust hose..
Put a mirror to the exaust hole trying to see inside to the eliment(s)..
When running - the eliment should glow hot..
If its not - it migt need to be replaced..
Hope this helps !!
rate me good ;o)
1helpful
Dryer does not dry clothes completely
Could be a clogged exaust path..
Or could be a heating eliment..
put a mirror to see inside the exaust hole - trying to see the eleent(s)..
When on - the eliment will glow hot..
If not - might need replacing..
Hope this helps !!
rate me good ;o)
Wirlpool dryer heating eliment keeps braking
Sounds like you use dryer sheets. If you do, try cleaning your lint screen with vinegar. Dryer sheets leave a film on the screen that the dryer eventually can't breathe through, the dryer overheats and burns up the elements.
Top Dryers Experts
john h
