Question about Brother MFC-640CW All-In-One InkJet Printer
B&W printing no longer works.
I believe that I've clogged the black print head by using cheap replacement ink. I've tried cleaning it several times with the printer's on-board method but it never works. From what I can tell, the print head is clogged.
Is there any way to clear this without having to buy a new print head? I would really appreciate any help.
I've gone into maintenance mode and checked for any error messages, but there are none.
  • 1 more comment
  • jg72 Feb 26, 2008
    Thanks - I will try this and report back!
  • jg72 Mar 04, 2008
    I've tried the clean and purge with no luck. I'm assuming that I have to replace the head. It appears that this will cost more than the price of a new printer... I'd love to fix this myself, but I can't justify the cost.
  • zuber1 Dec 20, 2008
    I also have this problem with my MFC 640CW.  We used cheap replacement ink and first we didn't have any yellow print, now we do not have any red ink coming out.  Can this be remedied by buying a OEM brother cartridge and purging the ink through to get it cleaned out?
  • 832 Answers
So, if you have achieved the maintenance mode, go back there and when entered press 7 then 6 then 4 then start bk-copy. Before that insert new original brother carts! machine will initiate the carts and do some power cleaning. when finished press 7 then 6 then 3 then start bk-copy. machine will do a power purge. leave maintenance mode by pressing 9 then 9 and -after machine comes up in a normal state- run a test print.
if you still cant see any bk blocks the head is definitly clogged and needs replacement.
NEVER use generic ink carts like easyjet, unink etc. because of wrong consistence of ink (only dye-ink with glycerol is allowed to use)
Posted on Feb 26, 2008
I installed a new black ink cartridge and now it won't print black even though it shows its full on in levels
If your black cartridge was empty for any length of time before you replaced it, even if it was still installed in the printer, chances are that the black print head nozzle has dried ink in it. Cleaning may or may not resolve the problem, but cleaning also uses obscene amounts of ink. Epson printers are notorious for clogs since they have some of the smallest print head nozzle sizes (thus their high dpi resolution).
There are some Youtube videos that suggest ways to clean severely clogged Epson print heads. I cannot vouch for them as I have never tried them, but you can view them and decide for yourself.
Feb 04, 2016 | Epson WorkForce WF-3620 Wireless Color...
Printer not printing black
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again......
Nov 17, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My printer will no longer print in black s520
if it is a new black ink cartridge and the printer still wont print black start by:
A: Simply making sure the settings are ok. To do this, go to file>print. When the printer box shows up. click properties.
From there, you will be able to see color settings. (ex. black, grayscale, full color.) Try switching to black or "use black cartridge only.
B. If "a" does not work for you, the print head which hold the ink cartridge is clogged or no longer working. Through the cannon window on the printer, try running a print head cleaning or any maintenance program.
If there's still no black, the print head has seen better days and needs replacing. Most of the time it is more effective to get a new printer.
May 22, 2011 | Canon Office Equipment & Supplies
My Canon S600 has no longer prints the colours nor black - even the nozzle check does not print. The printer goes through the motions, but the page is always blank. All ink tanks have ink in them. I...
I use to have a Canon with the same issue as yours. Do you refill your own ink tanks? If so, that is the problem because they leak inherently after awhile. If they leak then your print head is probably clogged. Was this a gradual problem or did it occur all at once? That will make a difference in troubleshooting your problem. Another issue with Canon printers is that you have to use them often of the print heads will clog up after a period of time. Take a look at this video as well. It may help you!
Jan 09, 2018 | Canon BJC S600 InkJet Printer
Every time I print, the printout always has black horizontal lines on top of the requested document. How do I fix this? This has now been happening for the past week.
Hi
I believe the print head is clog and need to clean it. Try this solution.
Remove the ink cartridge and clean the print head using a cloth with rubbing alcohol to remove clogged ink in the print head. Then rub the printhead into a plain paper until ink flows. Then try to print again
If still not working, run the print nozzle for 2-3 times to clean thoroughly.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 20, 2011 | Dell 926 All-In-One InkJet Printer
I have a Brother MFC-6490CW that my husband purchased for me somewhere between one and two years ago. I just recently decided to use it, and the black ink would not print. I thought the original...
Power purge the machine:
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Feb 25, 2011 | Brother MFC 6490CW InkJet Printer
HP 7780 suddenly stopped printing in red. I have changed the cartridges several times. I am using brand new HP cartridges. Have cleaned the print heads, aligned several times, nothing has heled. The...
Hi Good day!!!
Maybe your print head is clooged (red)
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like print head cleaning solution
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realizing the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and print head cleaning solution injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Thank you for using fixya
Jan 03, 2011 | HP Office Equipment & Supplies
My printer Canon MP760 does not print black.
Your black ink must be empty replace with a new one and print.
Sep 20, 2009 | Office Equipment & Supplies
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Canon i250 won't print in black
I had this problem also. There were short-term solutions, but nothing worked for any length of time. In the end the only solution was to buy a new printer.
Epson have deliberately built obsolence into these printers. After a pre-determined number of prints, they just stop working. Clever fixes keep them limping on a bit longer, but eventually you have no alternative but to replace them. On principle, you should therefore replace your planned-obsolescence printer with a non-Epson machine. But then you'll be left with your stock of cheap Chinese printer cartridges!
In the 1960s Ralph Nader made his name as a consumer champion by campaigning against US car companies. They used to build in pre-programmed obsolence into your car so that after a certain amount of time you were forced to buy a new one. Just like Epson is doing today.
Oct 04, 2008 | Office Equipment & Supplies
Brother MFC-640CW All-In-One InkJet Printer Logo
271 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
