not all the printers have that function.., the x6650 does not seem to have it but if the one you have do have it, setting up "duplexing" as it is called should be similar to this:
- Go to Start, Control Panel, Printers and Faxes. (If the display is in Category view, you will need to click Printers and other Hardware before clicking Printers and Faxes.)
- Right click on the Lexmark printer driver and select Properties.
- On the General tab of the Printer Properties screen, click Printing Preferences.
- Select the Print Layout tab.
- Under Duplexing *, select 2 sided and then indicate whether you wish to use the top flip or the side flip.
- Click OK to apply your changes.
* if you don't see duplexing your printer does not have that funcion.
now.. there's another alternative if you want to print more that one page per sheet:
Using Windows
1 With a document open, click
File -> Print.
2 Click
Properties,
Preferences,
Options, or
Setup.
3 From the
Advanced tab, select
N-Up under the Layout drop-down menu.
4 Select the number of page images to print on each page.
If you want each page image to be surrounded by a border, then select
Print Page Borders.
5 Click
OK to close any printer software dialogs.
6 Click
OK or
Print.
hope that helps
your printer user guide is
here
